Obtaining String Length
Function Name
$strLen(String A)
Parameter Description
- String A: original string whose length is requested.
Parameter A supports the following types:
- Strings
- Local parameters
Function Description
Obtains the length of a specified string.
Application Scenarios
The string length function can be used in the following scenarios for API automation cases:
- Request URL
- Request header
- Request body
- Checkpoint property
- if condition
- for loop interrupt condition
Example
- Request URL
As shown in the following figure, the value of test in the request URL is the string length function that uses the local parameter ${test}.
- Request header
As shown in the following figure, the value of test in the request header is the string length function whose parameter A is the local parameter ${test}.
- Request body
As shown in the following figure, the request body uses the string length function whose parameter A is the local parameter ${test}.
As shown in the following figure, the target value of the checkpoint property result is the string length function whose parameter A is the environment parameter $${info}.
- if condition
As shown in the following figure, the target value of the if condition is the string length function uses the local parameter ${test}.
As shown in the following figure, the target value of the for loop interrupt condition is the string length function uses the local parameter ${test}.
