Updated on 2025-08-19 GMT+08:00
Function Switch
  1. Log in to the CodeArts homepage, search for your target project, and click the project name to access the project.
  2. In the navigation pane, choose Settings > Testing.
  3. Click the Function Switch tab and enable or disable the following functions as required.
    • Requirement update dot: Updated requirements are indicated by a red dot next to their names in the requirement directory on the test case page. Click the red dot to see the change history. For details, see the instructions for associating test cases with requirements.
    • When importing a swagger file, use the fields defined by the API as the script template name: The default script template name is the value of operationId. You can turn on the switch to use the value of summary.
    • Interface automation testing supports redirection.: redirection during execution of automated API test cases.
    • Test design generates test cases step by step: Generate test cases on a mind map, with each step having an expected result. For details, see the instructions for step-by-step case generation.
    • Automatic roll-up of manual test suite results: If all the steps in a test case are Successful, the test case result will be automatically set to Successful; similarly, if all the test cases within a test case suite are Successful, the suite result will be automatically set to Successful.
