DubboClient
Introduction to Dubbo
Apache Dubbo is a microservice development framework that provides RPC communication and microservice governance. Microservices developed using Dubbo can remotely discover and communicate with each other. In addition, Dubbo provides rich service governance capabilities to meet service governance requirements such as service discovery, load balancing, and traffic scheduling.
Introduction to DubboClient
This system keyword is used to test the Dubbo protocol. Ensure that the Dubbo service is accessible from the public network and the security group policy of the corresponding port is enabled to permit access.
| Parameter | Mandatory | Type | Default Value | Description |
| Dubbo Server IP Address | Yes | String | - | IP address of the Dubbo service |
| Dubbo Server Port | Yes | Integer | - | Dubbo service port |
| Dubbo operation instruction | Yes | String | LS | Dubbo operation command. The options are LS and INVOKE. |
| Dubbo Registration API | Yes | String | - | Name of the API registered with Dubbo. It is a fully qualified class name. |
| Dubbo Registration API | Yes | String | - | Method signature corresponding to the API registered with Dubbo |
DubboClient Response
- Status: success
Type
Body
String
Value returned by the Dubbo service
Default Checkpoint
| Name | Expected Value |
| Result | Success |
DubboClient Usage Example: Obtaining All Registered APIs of the Server
Parameter example:
Response example:
DubboClient Usage Example: Obtaining the Specified Service Registration API of the Server
Parameter example:
Response example:
DubboClient Usage Example: Calling a Specified Dubbo API
Parameter example:
Response example:
