WSWriteOnly
This system keyword is used to access a WebSocket server for write-only operations.
Parameter |
Mandatory |
Type |
Description |
Request Uri |
Yes |
String |
WebSocket service address |
Response Timeout |
Yes |
Long |
Response timeout period |
Header |
Yes |
String |
Request header |
Request Type |
Yes |
String |
Request data type |
Request Body |
Yes |
String |
Request data |
WSWriteOnly Response
Status: success
Parameter |
Type |
Description |
Body |
String |
Value returned by the WSWriteOnly API |
WSWriteOnly Response Example
{ "Write data to *** at port *** successfully. response: this is a response message." }
Default Checkpoint
Name |
Expected Value |
Result |
Success |
WSWriteOnly Usage Example
Configure parameters to access the WebSocker service.
