PostgreSQLUpdate
This system keyword is used for modification operations on PostgreSQL database.
Parameter | Mandatory | Type | Description |
Ip | Yes | String | Database IP address. For a Huawei Cloud RDS instance, bind an EIP to the instance and ensure that the security group policy of the instance port is enabled to allow access. For details, see the connection methods. |
Port | Yes | Integer | Database port |
DB Name | Yes | String | Database instance name |
User Name | Yes | String | Username |
Password | Yes | String | Password (The login password is personal information and must be defined as sensitive in the environment parameters.) |
Sql | Yes | String | SQL statement, such as UPDATE, which has no returns |
PostgreSQLUpdate Response
Status: success
Parameter | Type | Description |
affected_row_count | Integer | Number of rows affected by the SQL statement |
PostgreSQLUpdate Response Example
"affected_row_count": 1
} PostgreSQLUpdate Usage Example
Determine the number of affected rows.
