PostgreSQLQuery
Updated on 2024-10-11 GMT+08:00
This system keyword is used for select operations on PostgreSQL database. A maximum of 100 result records can be queried in the system.
Mandatory
Type
Ip
Yes
String
Database IP address. For a Huawei Cloud RDS instance, bind an EIP to the instance and ensure that the security group policy of the instance port is enabled to allow access. For details, see Connecting to an RDS for PostgreSQL Instance.
Port
Yes
String
Database port
DB Name
Yes
String
Database instance name
User Name
Yes
String
Username
Password
Yes
String
Password (The login password is personal information and must be defined as sensitive in the environment parameters.)
Sql
Yes
String
SQL query statement
PostgreSQLQuery Response
Status: success
Type
[Array elements]
Array of row objects
Structure returned by the SQL query result list
Parameter Description
Type
field1
String
Database field 1
field2
Integer
Database field 2
String
Database field n
PostgreSQLQuery Response Example
        "name": "XXX",
        "id": "efdb403066474ab08836b9eeaaa23bca",
        "age": 18
        "name": "YYY",
        "id": "g582b0d966611486f918bedb9c711b14",
        "age": 20
PostgreSQLQuery Usage Example
Query the database table. A user data list is returned based on the system keyword. You can determine the return based on the service.
Determine the result in the returned list.
Query and collect user data. A user data list is returned.
Determine the result in the response extraction.
