OpenGaussDelete
This system keyword is used for deletion operations on openGauss database.
Parameter |
Mandatory |
Type |
Description |
Ip |
Yes |
String |
Database IP address. For a cloud-based GaussDB instance, bind an EIP to the instance and ensure that the security group policy of the instance port is enabled to allow access. For details, see Using gsql to Connect to an Instance. |
Port |
Yes |
Integer |
Database port |
DB Name |
Yes |
String |
Database instance name |
User Name |
Yes |
String |
Username |
Password |
Yes |
String |
Password (The login password is personal information and must be defined as sensitive in the environment parameters.) |
Sql |
Yes |
String |
SQL statement, such as DELETE, which has no returns |
OpenGaussDelete Response
Status: success
Parameter |
Type |
Description |
affected_row_count |
Integer |
Number of rows affected by the SQL statement |
OpenGaussDelete Response Example
"affected_row_count": 1
OpenGaussDelete Usage Example
Determine the number of affected rows.
