- What's New
- Function Overview
- Getting Started
User Guide
- Working with CodeArts TestPlan
- Enabling CodeArts TestPlan
- Accessing CodeArts TestPlan Homepage
- Configuring a Test Plan
- Configuring a Test Version
Configuring a Test Case
- Generating a Test Case
- Creating a Test Case by Using Mind Map
- Creating a Manual Test Case
Creating an Automated API Test Case
- Using Automated API Test Cases
- Creating an Automated API Test Case Template
- Adding an API Test Script by Using a Custom URL Request
- Adding an API Script by Importing a Postman File
- Adding an API Script by cURL
- Adding an API Script by Keyword Library
- Adding Logic Control to an API Script
- Setting Test Case Parameters of an API Script
- Setting Environment Parameters of an API Script
- Importing an Automated API Test Case Dataset
Built-in Functions
- Binary Addition Function
- Binary Subtraction Function
- Binary Multiplication Operation
- Binary Division Operation
- Obtaining the Current Timestamp
- Obtaining a Specified Timestamp
- Converting a Date into a Timestamp
- Converting a Timestamp into a Date
- Timestamp Addition and Subtraction Operations
- Generating Base64 Encoding
- Generating SHA512 Encoding
- Generating SHA256 Encoding
- Generating an MD5 Hash Value
- Generating a Random Number in a Specified Range
- Generating a Random String of a Specified Length
- Generating a Random Decimal in a Specified Range
- Generating a UUID
- Obtaining an Array via Reverse Index
- Obtaining the Element Values of an Array via Reverse Index
- Converting Uppercase Letters into Lowercase Letters
- Converting Lowercase Letters into Uppercase Letters
- Concatenating Strings
- Cutting Strings
- Obtaining String Length
System Keywords
- Overview
- GetIAMToken
- MySQLQuery
- MySQLUpdate
- MySQLInsert
- MySQLDelete
- OpenGaussQuery
- OpenGaussUpdate
- OpenGaussInsert
- OpenGaussDelete
- PostgreSQLQuery
- PostgreSQLUpdate
- PostgreSQLInsert
- PostgreSQLDelete
- MongoDBQuery
- MongoDBInsert
- MongoDBUpdate
- MongoDBDelete
- RedisGet
- RedisSet
- OBSWrite
- OBSDelete
- OBSQuery
- KafkaProducer
- KafkaConsumer
- TCP
- UDP
- WSConnect
- WSRequest
- WSWriteOnly
- WSReadOnly
- WSDisConnect
- DubboClient
- Executing a Test Case
- Managing Test Cases
- Creating and Executing a Test Suite
- Viewing and Evaluating Test Quality
- Settings
- API Reference
- Best Practices
- What Do I Do If No Test Case Exists in a Test Suite?
- What Can I Do If I Do Not Have the Operation Permission?
- Why Am I See a Message Indicating that an API Automation Test Suite Is Being Executed or Queuing?
- What Do I Do If a Test Suite Does Not Exist?
- Why Can't I Download the Document in a Manual Test Case?
- What Do I Do If No Test Case Exists In a Test Plan
- Why Can't I Add Work Items of the Task Type When a Test Plan Is Created or Updated?
- What Do I Do If Test Cases Cannot Be Associated with Work Items of the Task Type?
- What Do I Do If the Test Case Completion Rate in the Test Report Is Lower Than 100%?
- Why Is the Status of Test Cases in a Test Plan Inconsistent with That in a Test Case Library?
- How Are Variables Passed Between Steps in API Automation Cases?
- How Do I Set Checkpoints for Test Procedures in API Automation Cases?
- Videos
OpenGaussInsert
This system keyword is used for data insertion on openGauss database.
Parameter |
Mandatory |
Type |
Description |
Ip |
Yes |
String |
Database IP address. For a cloud-based GaussDB instance, you need to bind an EIP to the instance and ensure that the security group policy of the instance port is enabled to allow access. For details, see Using gsql to Connect to an Instance. |
Port |
Yes |
Integer |
Database port |
DB Name |
Yes |
String |
Database instance name |
User Name |
Yes |
String |
Username |
Password |
Yes |
String |
Password (The login password is personal information and must be defined as sensitive in the environment parameters.) |
Sql |
Yes |
String |
SQL statement, such as INSERT, which has no returns |
OpenGaussInsert Response
Status: success
Parameter |
Type |
Description |
affected_row_count |
Integer |
Number of rows affected by the SQL statement |
OpenGaussInsert Response Example
{ "affected_row_count": 1 }
OpenGaussInsert Usage Example
Determine the number of affected rows.
