- What's New
- Function Overview
- Getting Started
User Guide
- Working with CodeArts TestPlan
- Enabling CodeArts TestPlan
- Accessing CodeArts TestPlan Homepage
- Configuring a Test Plan
- Configuring a Test Version
Configuring a Test Case
- Generating a Test Case
- Creating a Test Case by Using Mind Map
- Creating a Manual Test Case
Creating an Automated API Test Case
- Using Automated API Test Cases
- Creating an Automated API Test Case Template
- Adding an API Test Script by Using a Custom URL Request
- Adding an API Script by Importing a Postman File
- Adding an API Script by cURL
- Adding an API Script by Keyword Library
- Adding Logic Control to an API Script
- Setting Test Case Parameters of an API Script
- Setting Environment Parameters of an API Script
- Importing an Automated API Test Case Dataset
Built-in Functions
- Binary Addition Function
- Binary Subtraction Function
- Binary Multiplication Operation
- Binary Division Operation
- Obtaining the Current Timestamp
- Obtaining a Specified Timestamp
- Converting a Date into a Timestamp
- Converting a Timestamp into a Date
- Timestamp Addition and Subtraction Operations
- Generating Base64 Encoding
- Generating SHA512 Encoding
- Generating SHA256 Encoding
- Generating an MD5 Hash Value
- Generating a Random Number in a Specified Range
- Generating a Random String of a Specified Length
- Generating a Random Decimal in a Specified Range
- Generating a UUID
- Obtaining an Array via Reverse Index
- Obtaining the Element Values of an Array via Reverse Index
- Converting Uppercase Letters into Lowercase Letters
- Converting Lowercase Letters into Uppercase Letters
- Concatenating Strings
- Cutting Strings
- Obtaining String Length
System Keywords
- Overview
- GetIAMToken
- MySQLQuery
- MySQLUpdate
- MySQLInsert
- MySQLDelete
- OpenGaussQuery
- OpenGaussUpdate
- OpenGaussInsert
- OpenGaussDelete
- PostgreSQLQuery
- PostgreSQLUpdate
- PostgreSQLInsert
- PostgreSQLDelete
- MongoDBQuery
- MongoDBInsert
- MongoDBUpdate
- MongoDBDelete
- RedisGet
- RedisSet
- OBSWrite
- OBSDelete
- OBSQuery
- KafkaProducer
- KafkaConsumer
- TCP
- UDP
- WSConnect
- WSRequest
- WSWriteOnly
- WSReadOnly
- WSDisConnect
- DubboClient
- Executing a Test Case
- Managing Test Cases
- Creating and Executing a Test Suite
- Viewing and Evaluating Test Quality
- Settings
- API Reference
- Best Practices
- What Do I Do If No Test Case Exists in a Test Suite?
- What Can I Do If I Do Not Have the Operation Permission?
- Why Am I See a Message Indicating that an API Automation Test Suite Is Being Executed or Queuing?
- What Do I Do If a Test Suite Does Not Exist?
- Why Can't I Download the Document in a Manual Test Case?
- What Do I Do If No Test Case Exists In a Test Plan
- Why Can't I Add Work Items of the Task Type When a Test Plan Is Created or Updated?
- What Do I Do If Test Cases Cannot Be Associated with Work Items of the Task Type?
- What Do I Do If the Test Case Completion Rate in the Test Report Is Lower Than 100%?
- Why Is the Status of Test Cases in a Test Plan Inconsistent with That in a Test Case Library?
- How Are Variables Passed Between Steps in API Automation Cases?
- How Do I Set Checkpoints for Test Procedures in API Automation Cases?
- Videos
GetIAMToken
Overview
This system keyword is used for obtaining an IAM user token through username or password authentication. A token is an access credential issued to an IAM user. It carries their identity and permissions. When calling APIs of IAM and other cloud services, you can use this system keyword to obtain an IAM user token.
Parameter Description
Parameter |
Mandatory |
Type |
Default Value |
Description |
IAM Token URL |
Yes |
String |
https://iam.myhuaweicloud.com/v3/auth/tokens |
IAM endpoint. This API can be called using both global and regional endpoints. |
Domain Name |
Yes |
String |
<Empty> |
IAM account or tenant name. When a Huawei account is used for login, the tenant (account) name is the same as the username. For details about how to obtain an account name, see Obtaining Account, IAM User, Group, Project, Region, and Agency Information. |
User Name |
Yes |
String |
<Empty> |
IAM username. For details about how to obtain a username, see Obtaining Account, IAM User, Group, Project, Region, and Agency Information. |
Password |
Yes |
String |
<Empty> |
IAM user login password. (The login password is personal information and must be defined as sensitive in the environment parameters.) |
Region ID |
No |
String |
<Empty> |
Region ID, for example, cn-north-1. For details about how to obtain a region ID, see Obtaining Account, IAM User, Group, Project, Region, and Agency Information. |
Default Checkpoint
Name |
Expected Value |
Result |
Success |
Default Response Extraction
Name |
Extraction Variable |
Description |
IAM_TOKEN |
X-Subject-Token |
User token character |
Response
- Status: success
Type
Body
Response body of the IAM API
- Example response
{ "token": { "catalog": [], "expires_at": "2020-01-04T09:05:22.701000Z", "issued_at": "2020-01-03T09:05:22.701000Z", "methods": [ "password" ], "project": { "domain": { "id": "d78cbac186b744899480f25bd022f...", "name": "IAMDomain" }, "id": "aa2d97d7e62c4b7da3ffdfc11551f...", "name": "cn-north-1" }, "roles": [ { "id": "0", "name": "te_admin" }, { "id": "0", "name": "op_gated_OBS_file_protocol" }, { "id": "0", "name": "op_gated_Video_Campus" } ], "user": { "domain": { "id": "d78cbac186b744899480f25bd022f...", "name": "IAMDomain" }, "id": "7116d09f88fa41908676fdd4b039e...", "name": "IAMUser", "password_expires_at": "" } }, "X-Subject-Token": "MIIatAYJKoZIhvcNAQcCoIIapTCCGqECAQExDTALB..." }
Example
- Obtaining an IAM user token
The Password field needs to be configured as a sensitive parameter in the variable. Select a value from the drop-down list box.
- Referencing a token in an API
IAM_TOKEN is the reserved default response extraction and can be directly referenced in the request.
