- What's New
- Function Overview
- Getting Started
User Guide
- Working with CodeArts TestPlan
- Enabling CodeArts TestPlan
- Accessing CodeArts TestPlan Homepage
- Configuring a Test Plan
- Configuring a Test Version
Configuring a Test Case
- Generating a Test Case
- Creating a Test Case by Using Mind Map
- Creating a Manual Test Case
Creating an Automated API Test Case
- Using Automated API Test Cases
- Creating an Automated API Test Case Template
- Adding an API Test Script by Using a Custom URL Request
- Adding an API Script by Importing a Postman File
- Adding an API Script by cURL
- Adding an API Script by Keyword Library
- Adding Logic Control to an API Script
- Setting Test Case Parameters of an API Script
- Setting Environment Parameters of an API Script
- Importing an Automated API Test Case Dataset
Built-in Functions
- Binary Addition Function
- Binary Subtraction Function
- Binary Multiplication Operation
- Binary Division Operation
- Obtaining the Current Timestamp
- Obtaining a Specified Timestamp
- Converting a Date into a Timestamp
- Converting a Timestamp into a Date
- Timestamp Addition and Subtraction Operations
- Generating Base64 Encoding
- Generating SHA512 Encoding
- Generating SHA256 Encoding
- Generating an MD5 Hash Value
- Generating a Random Number in a Specified Range
- Generating a Random String of a Specified Length
- Generating a Random Decimal in a Specified Range
- Generating a UUID
- Obtaining an Array via Reverse Index
- Obtaining the Element Values of an Array via Reverse Index
- Converting Uppercase Letters into Lowercase Letters
- Converting Lowercase Letters into Uppercase Letters
- Concatenating Strings
- Cutting Strings
- Obtaining String Length
System Keywords
- Overview
- GetIAMToken
- MySQLQuery
- MySQLUpdate
- MySQLInsert
- MySQLDelete
- OpenGaussQuery
- OpenGaussUpdate
- OpenGaussInsert
- OpenGaussDelete
- PostgreSQLQuery
- PostgreSQLUpdate
- PostgreSQLInsert
- PostgreSQLDelete
- MongoDBQuery
- MongoDBInsert
- MongoDBUpdate
- MongoDBDelete
- RedisGet
- RedisSet
- OBSWrite
- OBSDelete
- OBSQuery
- KafkaProducer
- KafkaConsumer
- TCP
- UDP
- WSConnect
- WSRequest
- WSWriteOnly
- WSReadOnly
- WSDisConnect
- DubboClient
- Executing a Test Case
- Managing Test Cases
- Creating and Executing a Test Suite
- Viewing and Evaluating Test Quality
- Settings
- API Reference
- Best Practices
- What Do I Do If No Test Case Exists in a Test Suite?
- What Can I Do If I Do Not Have the Operation Permission?
- Why Am I See a Message Indicating that an API Automation Test Suite Is Being Executed or Queuing?
- What Do I Do If a Test Suite Does Not Exist?
- Why Can't I Download the Document in a Manual Test Case?
- What Do I Do If No Test Case Exists In a Test Plan
- Why Can't I Add Work Items of the Task Type When a Test Plan Is Created or Updated?
- What Do I Do If Test Cases Cannot Be Associated with Work Items of the Task Type?
- What Do I Do If the Test Case Completion Rate in the Test Report Is Lower Than 100%?
- Why Is the Status of Test Cases in a Test Plan Inconsistent with That in a Test Case Library?
- How Are Variables Passed Between Steps in API Automation Cases?
- How Do I Set Checkpoints for Test Procedures in API Automation Cases?
- Videos
Function Name
$timeStampCalculation(longA, StringB)
Parameter Description
- longA: timestamp in milliseconds.
- StringB: time difference. The value is an integer plus a letter ("d": day; "h": hour; "s": second). For example, 1d indicates that one day is added to the specified timestamp, and -1d indicates that one day is subtracted.
Function Description
Implements the addition and subtraction operations between parameter A of the long type and parameter B of the string type. Parameters A and B support the following types:
- Value in the format listed in Parameter Description
- Local parameters
- Other built-in functions
Application Scenarios
Timestamp addition and subtraction operations can be used in the following scenarios for API automation:
- Request URL
- Request header
- Request body
- Checkpoint property
- if condition
- for loop interrupt condition
Example
- Request URL
As shown in the following figure, the value of test in the request URL is the timestamp addition and subtraction function. Parameter A in the function is 1607939485441, and parameter B is 1d.
- Request header
As shown in the following figure, the value of time in the request header is the timestamp addition and subtraction function. Parameter A in the function is the date-to-timestamp conversion function $dateFormat(2020.09.11 11:00:00), and parameter B is -86400s.
- Request body
As shown in the following figure, the request body uses the timestamp addition and subtraction function. Parameter A in the function is $dateFormat(2020.09.11 11:00:00), and parameter B is 1d.
As shown in the following figure, the target value of the checkpoint property result is the timestamp addition and subtraction function. Parameter A in the function is the environment parameter time, and parameter B is -24h. For details about how to set environment parameters, see Setting Environment Parameters of an API Script.
- if condition
As shown in the following figure, the target value of the if condition is the timestamp addition and subtraction function. Parameter A in the function is the environment variable status, and parameter B is 1d. For details about how to set environment parameters, see Setting Environment Parameters of an API Script.
As shown in the following figure, the target value of the for loop interrupt condition is the timestamp addition and subtraction function. Parameter A in the function is 1607939485441, and parameter B is 1d.
