Help Center/ CodeArts TestPlan/ User Guide/ Configuring a Test Case/ Creating an Automated API Test Case/ Adding an API Script by Importing a Postman File
Updated on 2026-08-11 GMT+08:00
Background
Test steps can be generated by importing Postman files for automated API test cases.
Requirements:
- The Postman Collection v2.1 standard is supported.
- Use only the Postman request method, URL, header, and body to generate test steps.
- Use only the form-data, x-www-form-urlencode, or raw modes to import the Postman request body.
- Upload the Postman request form-data attachment separately in test steps.
- After the operations described in Creating an Automated API Test Case Template are complete, click the test case name, and click the Scripting tab.
- Click Postman. In the displayed dialog box, click
, select the file to be imported, and click OK. - The URL request is displayed on the page. Click Save in the upper right corner. The system displays a message indicating that the update is successful.
If the saving fails, a dialog box is displayed in the upper right corner, indicating the failure cause.
Parent topic: Creating an Automated API Test Case
