Setting Checkpoints for an API Script
Updated on 2025-01-10 GMT+08:00
Suggestions
You are advised to set checkpoints. For API requests, you need to provide checkpoints for determining response codes.
If the checkpoints are left empty, the result is success regardless of the response code of the API.
Checkpoint Description
A test checkpoint is also called assertion. It determines whether the system meets the expectation based on the API response.
On the Checkpoints tab page of the test step in the test case details of API automation, you can define test checkpoints.
Checkpoint parameters include Property, Comparison Operator, and Target Value.
Retries
Number of times that the test step is re-executed if the checkpoint fails. The value is an integer ranging from 0 to 5.
Retry Interval
Interval for retrying a checkpoint if the checkpoint fails. The unit is ms. The value is an integer ranging from 0 to 10,000.
Source
Source of the detected field, such as the response body (JSON), response header, response code, and variable.
Property
Enter $ to invoke global variables, local variables, and built-in functions.
Advanced Extraction Type
(Optional) Use the advanced extraction type to assist in extracting checkpoint information. If N/A is selected, no additional matching mode is used.
Currently, there are two modes:
For the advanced extraction type, the string extraction function is preferred. If the function cannot meet the requirements, you can use the regular expression.
Type Value
Parameter required in the advanced extraction type.
Comparison Operator
Comparison operator, such as numbers, strings, JSON objects, and types, are supported. For details, see Comparison Operator Description.
Target Value
Expected value of a checkpoint. Built-in parameters can be used for target values. For details, see Built-in Parameters.
For example, the following table describes the parameter settings to check whether the range from the 0th digit (first digit) to the 4th digit of the item.name field in the response body (JSON format) is petty.
Value
Source
Response body (JSON)
Property
item.name
Character string extraction
Type Value
0–5
Comparison Operator
Equals (string)
Target Value
petty
Character String Extraction Description
When setting checkpoints or response extraction, if the expressions in the property setting bar cannot meet the requirements, you can set Advanced Extraction Type to Character string extraction.
There are two Type Value text boxes for string truncation:
  • The first box indicates the start index. The first digit is 0. The start index is contained in the truncated string.
  • The second box indicates the end index. The end index is not contained in the truncated string.
The following response body is used as an example.
  • To extract the fifth to ninth digits of code in the first element of the result array from the response body and compare them with the target value, configure the checkpoints by referring to the following figure.
  • To extract the fifth to ninth digits of code in the first element of the result array in the response body and assign the value to the variable code, configure the response extraction by referring to the following figure.
Regular Expression Description
When setting checkpoints or response extraction, if the expressions in the property setting bar or the character string extraction function cannot meet the requirements, you can set Advanced Extraction Type to Regular expression.
The Java regular expression engine can be used.
  • To verify the IP value of remoteUrl in the first element of the result array in the response body, use regular expression for matching and enter the target value in the checkpoint setting area. The following figure shows an example. Set Type Value to ((2[0-4]\d|25[0-5]|[01]?\d\d?)\.){3}(2[0-4]\d|25[0-5]|[01]?\d\d?).
  • To extract the IP value of remoteUrl in the first element of the result array in the response body, and assign the value to the variable remoteIp, use regular expression for matching and set the response extraction by referring to the following figure. Set Type Value to ((2[0-4]\d|25[0-5]|[01]?\d\d?)\.){3}(2[0-4]\d|25[0-5]|[01]?\d\d?).
CodeArts TestPlan supports the following comparison types.
Comparison Type
Comparison Operator
Value Mandatory or Not
Example
Digit
Yes
  • Response code = 200
  • Response code != 200
  • Response code >= 200
  • Response code <= 200
  • Response code > 200
  • Response code < 200
String
  • Equals
  • Does not equal
  • Equals (case insensitive)
  • Contains
  • Does not contain
Yes
  • Parameter 1 in the response body equals test.
  • Parameter 2 in the response body does not equal test.
  • Parameter 3 in the response body equals TEST.
  • Parameter 4 in the response body contains tri.
  • Parameter 5 in the response body does not contain tri.
Regular expression
Regular expression
Yes
  • Regular expression for parameter 1 in the response body: ^[A-Za-z0-9]{1,32}$
General
  • Is empty
  • Is not empty
No
  • Parameter 1 in the response body is empty.
  • Parameter 2 in the response body is not empty.
JSON array
  • Has null JSON array
  • Has non-null JSON array
No
  • Parameter 1 in the response body has a null JSON array.
  • Parameter 2 in the response body has a non-null JSON array.
JSON array size
Yes
  • Size of the parameter 1 JSON array in the response body.
Type
  • Is JSON type
  • Is JSON array type
No
  • Parameter 1 in the response body is of the JSON type.
  • Parameter 2 in the response body is of the JSON array type.
JSON object
JSON value
Yes
  • The JSON value of parameter 1 in the response body is {"name":"zhangsan"}.
Response Code Check
Compare the response code with the target value. For example, check whether the response code is 200.
Response Header Check
Compare the value of a field in the response header with the target value. For example, check whether the value of content-type in the response header is equal to text/plain;charset=UTF-8.
Response Body (JSON) Check
  1. Check the value of the object field in the response body (JSON). For example:
    The response body structure is as follows.
    To check the value of the field whose name is status in the response body object, configure the checkpoint by referring to the following figure.
  2. Check the field value of an array object in the response body (JSON). (The array condition uses the subscript starting from 0 to determine the object.) For example:
    To check the value of userId in the first element object field of the result array in the response body, configure the checkpoint by referring to the following figure.
  3. Check the field value of an array object in the response body (JSON). (The array condition uses the fuzzy match function to determine the object.) For example:
    1. Check all objects whose name is beer in the result array of the response body. Obtain the values of id after the first object. Configure the checkpoint by referring to the following figure.
      If there is only one object in the obtained array, [0] can be omitted. The expression in the example can be written as result[name==beer].id.
    2. Check the ID of the object whose name in the result array of the response body is beer, and of which the a property under obj is 2. Configure the checkpoint by referring to the following figure.
Variables Check
Check global variables, local variables, and variable values after response extraction, and compare them with target values. For example:
  • Check whether the value of the global variable hostIp is 127.0.0.1.
  • Check whether the value of the local variable local is text.
  • Check whether the value of the variable name after response extraction is Liquor.
Example: Obtaining a String from the Response Body Based on the Specified key:value
You can enter an array whose subscript is in the key:value format for the Property field of the check body to obtain the JSON string that meets the condition from the response body based on the specified key:value.
The following connectors are supported between key:value.
Connector
Example
Equals (string or digit)
name==John
age==20
Does not equal (string or digit)
name!=John
age!=20
Greater than (digit)
age>20
Greater than or equal to (digit)
age>=20
Less than (digit)
age<20
Less than or equal to (digit)
age<=20
The array subscript supports multiple groups of key:value conditions connected by &&, indicating that the extracted JSON string must meet all key:value conditions. For example, student[age>20&gender=female] indicates that the extraction conditions are that the age must be greater than 20 and the gender must be female.
The search criteria of an array support nested arrays. In this case, the sub-condition can be met only when all objects in the nested condition meet the conditions.
  • If the value is an empty object, use $null, that is, key==$null.
  • If the value is a null string ("null"), use null, that is, key==null.
  • If the value is an empty string (""), use key==.
  • If the property value of a checkpoint contains special characters, use single quotation marks or double quotation marks as boundary characters.
    For example, name=="zhangsan(ab)".
The following response body (JSON) is used as an example:
	"status": "success",
	"result": [
			"name": "Beer",
			"quantity": "20"
			"address": "Shelf 10 in repo A3",
			"obj": {
				"a": 1,
				"b": "test",
				"c": "test"
			"array": [
					"id": 1,
					"name": "aaa"
					"id": 2,
					"name": "bbb"
			"name": "Beer",
			"quantity": "10",
			"obj": {
				"a": 1,
				"b": "test",
				"c": "test"
			"array": [
					"id": 1,
					"name": "aaa"
					"id": 2,
					"name": "bbb"
			"name": "Liquor",
			"quantity": "20"
			"obj": {
				"a": 1,
				"b": "test",
				"c": "test"
			"array": [
					"id": 1,
					"name": "aaa"
					"id": 2,
					"name": "bbb"
			"name": "Liquor",
			"quantity": "30"
			"obj": {
				"a": 1,
				"b": "test",
				"c": "test"
			"array": [
					"id": 3,
					"name": "aaa"
					"id": 4,
					"name": "bbb"
			"name": null,
			"quantity": "10",
			"obj": {
				"a": 2,
				"b": "test",
				"c": "test"
			"array": [
					"id": 5,
					"name": "aaa"
					"id": 6,
					"name": "bbb"
			"name": "",
			"quantity": "10",
			"obj": {
				"a": 2,
				"b": "test",
				"c": "test"
			"array": [
					"id": 5,
					"name": "aaa"
					"id": 6,
					"name": "bbb"
	"condition": [
			"name": "Beer",
			"quantity": "120",
			"address": "Shelf 15 in warehouse A1",
	"reason": null
The following table lists the expressions for obtaining data from the response body.
Extraction Condition
Expression
Obtain the data whose name is Liquor from the result array.
result[name==Liquor]
Obtain the data whose name is not Beer and quantity is greater than 20 from the result array.
result[name!=Beer&&quantity>20]
Obtain the data whose name is a null object and id is less than or equal to 2 from the result array.
result[name==$null&&array[id<=2]]
Obtain the data whose name is a null string and property a under obj is 2 from the result array.
result[name==null&&obj.a==2]
Obtain the data whose name is an empty string ("") from the result array.
result[name==]
If you need to check whether the data (JSON) whose name is Liquor and quantity is greater than 20 is [{"name": "Liquor", "quantity": "30", " address": "Shelf 10 in warehouse A3", "obj": {"a": 1, "b": "test", "c": " test"}, "array": [{"id": 3, "name": "aaa"}, {"id": 4, " name": "bbb"}]], refer to the following table for the configuration of each field.
Value
Source
Property
Comparison Operator
Equals (string)
Target Value
[{"name": "Liquor", "quantity": "30"," address": "Shelf 10 in warehouse A3", "obj": {"a": 1, "b": "test", "c": " test"}, "array": [{"id": 3, "name": "aaa"},{"id": 4," name": "bbb"}]]
Example: Obtaining Data from the Response Body Based on JSONPath
For details about JSONPath, visit the official website.
    "store": {
        "book": [
                "category": "reference",
                "author": "Nigel Rees",
                "title": "Sayings of the Century",
                "price": 8.95
                "category": "fiction",
                "author": "Evelyn Waugh",
                "title": "Sword of Honour",
                "price": 12.99
                "author": "Herman Melville",
                "title": "Moby Dick",
                "isbn": "0-553-21311-3",
                "price": 8.99
                "author": "J. R. R. Tolkien",
                "title": "The Lord of the Rings",
                "isbn": "0-395-19395-8",
                "price": 22.99
        "bicycle": {
            "color": "red",
            "price": 19.95
    "expensive": 10
The JSONPath expression can contain dots (.) or brackets ([]). For example:
  • $.store.book[0].title
  • $['store']['book'][0]['title']
The following table describes the JSONPath expressions and their meanings.
JSONPath Expression
$.store.book[*].author
The authors of all books.
$..author
All authors.
$.store.*
All things, both books and bicycles.
$.store..price
The price of everything.
$..book[2]
The third book.
$..book[-2]
The second to last book.
$..book[0,1]
The first two books.
$..book[:2]
All books from index 0 (inclusive) until index 2 (exclusive).
$..book[1:2]
All books from index 1 (inclusive) until index 2 (exclusive).
$..book[-2:]
Last two books.
$..book[2:]
Book number two from tail.
$..book[?(@.isbn)]
All books with an ISBN number.
$.store.book[?(@.price < 10)]
All books in store cheaper than 10.
$..book[?(@.price <= $['expensive'])]
All books in store that are not "expensive".
$..book[?(@.author =~ /.*REES/i)]
All books matching regex (ignore case).
Give me everything.
If the length or size function is used, do not use deep scanning (that is, the .. symbol) when calling the function for multiple times. For example, if $..book.length() returns the number of books, you need to determine the path and change it to $.store.book.length().
