Updated on 2026-07-16 GMT+08:00
Modifying a Recycling Policy
You can rebuild unsubscribed yearly/monthly DB instances and deleted pay-per-use or serverless DB instances in the recycle bin.
The recycle bin is enabled by default and cannot be disabled.
Billing
Yearly/Monthly, pay-per-use, and serverless DB instances in the recycle bin are no longer billed, but manual backups retained for these DB instances are still billed. You can delete the manual backups to save costs. For details about backup pricing, see How Is TaurusDB Backup Data Billed?
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Recycle Bin page, click Modify Recycling Policy. In the displayed dialog box, set Retention Period (value range: 1 to 7, in days).
    The new recycling policy only applies to DB instances deleted after the modification.
    Figure 1 Modifying the recycling policy
  4. Click OK.
  5. After the modification is successful, click Modify Recycling Policy on the Recycle Bin page to view the new recycling policy.
