Viewing Metrics
The Metrics page allows you to monitor TaurusDB instances.
- You can view real-time performance metrics and trends of all instances in your account. This allows you to quickly identify and address any abnormal instances.
- You can also view historical performance metrics.
Viewing Metrics
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - In the navigation pane, choose Metrics.
- View the real-time performance metrics of a created TaurusDB instance under the current account. Figure 1 Viewing real-time metrics
Table 1 Parameter description Parameter
Node Name/ID
Only monitoring data for the nodes of a created TaurusDB instance is displayed.
Status
The value can be:
- Normal: Real-time monitoring data is displayed. NOTE:
The monitoring data and charts are available for a new instance after the instance runs for about 10 minutes.
- Abnormal: There is no monitoring data. The default values for all metrics are 0. The monitoring data is only available after the instance becomes normal.
- Stopped: There is no monitoring data. The default values for all metrics are 0. The monitoring data is only available after the instance is started.
Node Type
The value can be:
- Primary
- Replica
Availability Zone
AZ where a node is located
Private IP Address
Private IP address of a node
Failover Priority
Failover priority of a node
Metrics
For details about metric description and handling suggestions for abnormal metrics, see Table 2. The following metrics are available:
- CPU Usage
- Memory Usage
- TPS
- QPS
Table 2 Monitoring items Item
Handling Suggestion
Reference
CPU Usage
CPU usage of the monitored object
- Evaluate the SQL execution plan and add indexes to avoid full table scanning.
- Upgrade vCPUs for compute-intensive workloads.
What Should I Do If the CPU Usage of My TaurusDB Instance Is High?
Memory Usage
Memory usage of the monitored object
- Upgrade instance specifications.
- Optimize SQL statements to reduce the use of temporary tables.
- Reconnect sessions at a specific interval to release memory of the sessions.
TPS
Execution times of submitted and rollback transactions per second
QPS
Query times of SQL statements (including stored procedures) per second
- You can view the metrics of up to six nodes at a time.
- You can view the performance metrics in the last 1 hour, last 3 hours, last 12 hours, last 24 hours, or last 7 days. You can also configure a time period.
- You can move the cursor to a point in time of a chart to view the performance metric at that point in time. Figure 3 Viewing a performance metric at a point in time
