Help Center/ TaurusDB/ User Guide/ Parameter Management/ Modifying Parameters of a DB Instance
Updated on 2026-06-04 GMT+08:00
You can modify parameters of a DB instance to optimize performance if needed.
Precautions
  • To ensure DB instance stability, you can only modify the parameters that are available on the console.
  • To apply certain parameter modifications, you need to reboot the DB instance. After you modify a parameter value, check the value in the Effective upon Reboot column. You are advised to perform the operation during off-peak hours.
  • The value of validate_password.length cannot be smaller than that of validate_password.number_count+validate_password.special_char_count+(2 * validate_password.mixed_case_count). Otherwise, the allowed minimum value of validate_password.length is used when the parameter template is applied.
  • If you want to use a custom parameter template during instance creation, ensure that the value of validate_password.length in the template is at most 16. Otherwise, the DB instance fails to be created.
  • If you want to use a custom parameter template during instance creation, ensure that the values of validate_password.mixed_case_count, validate_password.number_count, and validate_password.special_char_count are at most 4. Otherwise, the DB instance may fail to be created. The default value 1 is recommended.
  • The options of rds_compatibility_mode depend on the kernel version of your TaurusDB instance.
  • The PAD_CHAR_TO_FULL_LENGTH option of sql_mode automatically pads CHAR column values with spaces to their full defined length. For example, if column a is defined as CHAR(10) and this option is used, data abc will be padded with seven trailing spaces. This can lead to failures in commands like CHANGE MASTER and START SLAVE. So, you are advised not to set sql_mode to this option.
  • Before modifying parameters, make sure you understand their meanings and fully verify the changes in a test environment to avoid instance or service exceptions caused by inappropriate parameter settings.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name.
  4. In the navigation pane, choose Parameters.
    Alternatively, click in the upper right corner of the Basic Information page and choose Modify Parameters.
    Figure 1 Choosing Modify Parameters
  5. On the Parameters tab, modify parameters.
    Figure 2 Modifying parameters of a DB instance
    • To save the modifications, click Save. In the displayed dialog box, click OK.
    • To cancel the modifications, click Cancel.
    • To preview the modifications, click Preview.
      Figure 3 Previewing parameters
  6. After the parameters are modified, click Change History to view the modification records.
    Figure 4 Viewing the modification records
You can modify parameters in a custom parameter template and then apply the template to multiple DB instances.
  3. In the navigation pane, choose Parameter Templates. On the Custom Templates tab, click the parameter template name.
  4. On the displayed Parameters page, modify parameters as required.
    Figure 5 Modifying parameters in a parameter template
  5. After the parameters are modified, click Change History to view the modification records.
  6. After a parameter template is modified, the modification will not take effect until the template is applied to DB instances. On the Parameter Templates page, locate the parameter template you want to apply and choose More > Apply in the Operation column.
    Figure 6 Applying a parameter template to DB instances
  7. Select desired DB instances and click OK.
    Figure 7 Select desired DB instances
  8. After the parameter template is applied, click a DB instance name and check whether the parameters have been modified on the Parameters page.
Common Parameters
Table 1 Common parameters
Reference
time_zone
Specifies the time zone of the server.
How Do I Change the Time Zone?
default_password_lifetime
Specifies the global automatic password expiration policy, in days.
How Do I Configure a Password Expiration Policy for TaurusDB Instances?
character_set_server
Specifies the server character set.
How Do I Use the utf8mb4 Character Set to Store Emojis in a TaurusDB Instance?
collation_server
Specifies the collation for the character set of the server. The collation must match the character set specified by character_set_server. Otherwise, the database cannot be started or restarted.
group_concat_max_len
Specifies the maximum permitted result length in bytes for the GROUP_CONCAT() function.
max_connections
Specifies the maximum number of concurrent client connections. If this parameter is set to default, the parameter value depends on how much memory there is.
What Is the Maximum Number of Connections to a TaurusDB Instance?
max_prepared_stmt_count
Limits the total number of prepared statements in the server. Too many statements may cause the server to run out of memory (OOM) and risk denial-of-service attacks. Configure this parameter as needed.
innodb_flush_log_at_trx_commit
Controls the balance between strict ACID compliance for commit operations, and higher performance that is possible when commit-related I/O operations are rearranged and done in batches. When this parameter is set to 0, the content of the InnoDB log buffer is written to the log file approximately once per second and the log file is flushed to disk. The default value of 1 is required for full ACID compliance. With this value, the contents of the InnoDB log buffer are written out to the log file at each transaction commit and the log file is flushed to disk. When this parameter is set to 2, the contents of the InnoDB log buffer are written to the log file after each transaction commit and the log file is flushed to disk approximately once per second.
TaurusDB Parameter Tuning
sql_mode
Specifies the SQL server mode.
binlog_expire_logs_seconds
Specifies the binary log expiration period in seconds. After their expiration period ends, binary log files can be automatically removed.
