Updated on 2025-08-21 GMT+08:00
Deleting a RegionlessDB Cluster
You can delete a RegionlessDB cluster.
- Before deleting a RegionlessDB cluster, ensure that all standby instances have been removed from it. For details about how to remove a standby instance, see Removing a Standby Instance from a RegionlessDB Cluster.
- For more constraints, see Constraints.
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page and choose Databases > TaurusDB.
- In the navigation pane, choose RegionlessDB.
- Locate a cluster and click Delete in the Operation column.
- If you have enabled operation protection, click Start Verification in the displayed dialog box. On the displayed page, click Send Code, enter the obtained verification code, and click Verify to close the page.
For details about how to enable operation protection, see Identity and Access Management User Guide.
- In the Delete RegionlessDB dialog box, select or deselect Delete instances in RegionlessDB as required, enter DELETE in the text box, and click OK.
Figure 1 Deleting a RegionlessDB cluster
- Refresh the RegionlessDB cluster list later to confirm that the deletion was successful.
To view the detailed progress and result of the task, go to the Task Center page.
