What Is a RegionlessDB Cluster?
A RegionlessDB cluster consists of multiple TaurusDB instances in different regions around the world. Currently, a RegionlessDB cluster consists of one primary instance (in the primary region) and up to five standby instances (in standby regions). Data is synchronized between primary and standby instances, providing nearby access and regional DR capabilities.
Basic Concepts
- Remote multi-active deployment
Data is synchronized among instances in a RegionlessDB cluster. For lower network latency and quicker resource access, you can select the instance nearest to your workloads.
- Remote disaster recovery
If there is a region-level fault on the primary instance, workloads can be switched to a standby instance for remote DR.
Architecture
- Cross-region deployment is supported. Redo logs generated in the primary instance are synchronized to a standby instance and written to DFV storage. Pages required for database access are replayed. For details, see Figure 2. (Data is synchronized based on the replication node Source of the primary instance and the replication node Target of the standby instance.)
- In the primary instance, the read replica obtains required redo logs and pages from DFV storage through the primary node. In the standby instance, the read replica obtains required redo logs and pages from DFV storage through the replication node Target.
Advantages
- Global deployment and nearby data access
Instances in a RegionlessDB cluster are from different regions around the world. Data generated by the primary instance can be directly read from the nearest standby instance.
- Low latency of cross-region replication
Redo logs are directly and uninterruptedly read from the DFV storage for asynchronous replication. The replication latency is less than 1 second thanks to high-throughput parallel data synchronization.
- No downtime for the primary node during data synchronization
The replication node of the primary instance reads data from different nodes in the DFV storage in parallel for synchronization. This means that the primary node does not need to directly synchronize data to the standby instances. Instead, it only needs to update the location information of redo logs in the storage to the replication node of the primary instance. In this way, workloads on the primary node are not affected.
- Too many read replicas
There are up to five standby instances in a cluster, and each standby instance supports up to 15 read replicas.
When creating a DB instance, you can create up to 10 read replicas at once.
- Region-level disaster recovery
If there is a region-level fault on the primary instance, workloads can be quickly switched to a standby instance for remote DR, achieving an RPO in minutes and an RTO in seconds.
- Before using this feature, you need to obtain the data security compliance requirements of the local region and evaluate the compliance with related laws and regulations.
- RegionlessDB clusters are in the OBT phase. To use them, submit a service ticket.
- To enable communication between regions, you need to create a Virtual Private Network (VPN) in advance. For details about how to create a VPN, see Configuring Enterprise Edition S2C VPN to Connect an On-premises Data Center to a VPC.
- Only pay-per-use instances can be created.
- The kernel version must be 2.0.46.231000 or later, and the primary instance must be a new instance. For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
- The instances in a RegionlessDB cluster cannot use 192.168.0.0/16 as their subnet CIDR block.
- The subnet CIDR blocks of the primary and standby instances in different regions must be different.
- When a standby instance is created, data needs to be synchronized from the primary instance. The time required depends on how much data there is.
- The primary instance in a RegionlessDB cluster cannot be restored to the original instance, and other instances cannot be restored to any instance in a RegionlessDB cluster.
- If you have created proxy instances or HTAP instances for a TaurusDB instance, the TaurusDB instance cannot be used as an instance in a RegionlessDB cluster. To use it, delete the proxy instances or HTAP instances first.
- The primary instance does not support the following operations:
- Changing a database port
- Changing a private IP address
- Creating an HTAP instance
- Creating a proxy instance
- The standby instance does not support the following operations:
- Resetting a password
- Creating and restoring a backup
- Creating an account
- Authorizing an account
- Promoting a read replica to the primary node
- Modifying auto scaling policies
- Data across regions is synchronized through a network. The VPN bandwidth must be greater than the write bandwidth of the primary instance in a RegionlessDB cluster.
- In large-scale DDL scenarios, the replication latency may fluctuate for more than 1 second.
- RegionlessDB clusters do not support OpenAPIs.
- A RegionlessDB cluster consists of one primary instance (in the primary region) and up to five standby instances (in standby regions). The primary instance processes both read and write requests, while the standby instances only process read requests. Table 1 lists the maximum specifications supported by a RegionlessDB cluster.
Table 1 Specifications Description
Primary Instance
Standby Instance
Max. Instances
Max. Read/Write Nodes per Instance
Max. Read-only Nodes per Instance
15
15
When you are creating a DB instance, a maximum of 10 read replicas can be created at once.
