Updated on 2026-07-16 GMT+08:00
What Is ALT?
Database sessions may be interrupted when a read replica is promoted to primary, a minor version is upgraded, or specifications are changed. Applications need to check session statuses and react to changes by determining: whether a database connection or transaction has been interrupted, how to compensate for transactions, and how to rebuild session contexts.
To address these issues, TaurusDB provides ALT, which prevents database connection and transaction interruptions during database system switchover. There is no need to compensate for transactions or rebuild session contexts, ensuring application continuity.
Architecture
Figure 1 Architecture
ALT can be enabled for your application connections. When you connect to a proxy instance and then promote a read replica to primary, change specifications, or upgrade the minor version, the system can replicate your backend sessions. Once a secure transaction boundary is reached, backend sessions will be fully cloned to the destination node, and workloads do not even notice.
ALT requires no active transactions on each connection. When promoting a read replica to primary, you need to wait for ongoing transactions to end. The interval for waiting for the transactions to end is called the transaction draining timeout interval, which is controlled by rds_tac_drain_timeout. This parameter defaults to 5s and ranges from 1s to 60s.
Increase this interval for heavy workloads, numerous prepared statements, or time-consuming transactions. Decreasing this interval is not recommended. If there are connections that do not drain transactions within the configured transaction draining timeout interval, ALT does not take effect for these connections.
Basic Concepts
Secure transaction boundary: it refers to the state where a transaction in the current session has been committed and the next transaction has not started.
A secure transaction boundary can be reached after:
  • Each statement in a transaction block with autocommit enabled is executed.
    start transaction;
    DML;
    commit;
  • The commit operation is complete with autocommit disabled.
  • A single DML or DDL statement is executed.
  • A table lock, backup lock, or user-defined lock is released.
Precautions
Table 1 Precautions
Category
Precautions
Version constraints
  • The kernel version of the TaurusDB instance must be 2.0.54.240600 or later.
  • The kernel version of the proxy instance must be 2.24.06.000 or later.
For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
Usage constraints
  • The TaurusDB instance has at least one read replica. A proxy instance has been created and the TaurusDB instance must be connected through the proxy address.
  • Proxy instances in read-only mode do not support ALT.
  • Single-node or multi-primary TaurusDB instances do not support ALT.
  • During an ALT switchover, standby connections will be established on the new host for a brief period, equal in number to those on the original primary node. Ensure that the maximum number of connections of the TaurusDB instance is at least twice the current number of connections. To change the maximum number of connections, you need to evaluate the instance specifications and memory usage. For details, see What Is the Maximum Number of Connections to a TaurusDB Instance?
  • If you want to use ALT during an instance-level specification change, ensure that the maximum connection limit of the primary node is at least twice the current number of active connections. Before modifying the maximum connection limit, evaluate the instance specifications and memory usage. For details, see What Is the Maximum Number of Connections to a TaurusDB Instance?
    Some connections will be retained after the specification change is complete, depending on your configuration of the connection timeout parameter (wait_timeout, which specifies the number of seconds the server waits for activity on a non-interactive connection before closing it).
  • ALT supports prepared statements. During a switchover, the contexts of prepared statements are rebuilt. If there are a large number of prepared statements, the switchover success rate may be affected. Ensure that the value of max_prepared_stmt_count is at least twice the number of prepared statements. Before changing the value of max_prepared_stmt_count, evaluate the instance specifications and memory usage. For details, see Modifying Parameters of a DB Instance.
    You can run the following SQL statement to query the number of prepared statements:
    show global status like 'prepared_stmt_count';
  • You are advised to perform an ALT switchover during off-peak hours. If the primary node and read replicas are overloaded, the switchover success rate may be affected.
  • For details about syntax and function constraints of proxy instances, see Precautions for TaurusDB Proxy Instances.
Unsupported functions
  • Enabling ALT makes your instance lose support for some system variable values.
    • innodb_ft_user_stopword_table: It can only be set to NULL.
    • transaction_write_set_extraction: It can only be set to OFF.
    • profiling: It cannot be set to 1 or ON.
  • ALT does not support Transparent Data Encryption (TDE).
  • ALT is unavailable when any of the following proxy capabilities is enabled:
    • Session-level connection pool
    • Global consistency
    • Any column containing more than 16 MB of data
    • Any query result set containing more than 16 MB of data
    • Prepared statement cache
  • ALT does not support temporary tables created by users.
  • ALT is not supported in the following scenarios where a secure transaction boundary cannot be reached:
    • InnoDB transaction blocks are not committed in a timely manner.
    • There are unreleased table locks, user locks, backup locks, and binlog locks.
    • XA transactions are not committed or rolled back.
  • ALT is likely to fail if a switchover, minor version upgrade, or specification change occurs frequently within a short period of time.
  • If ALT is enabled, prepared statements cannot be transferred in the following scenarios:
    • The cursor is opened and not closed in a prepared statement.
    • The variable in a prepared statement has saved the LONG_DATA type.
