Updated on 2026-04-20 GMT+08:00
Binding an EIP to a Proxy Instance
After a proxy instance is created, you can bind an EIP to it. Later, you can also unbind the EIP from the proxy instance as required.
Billing
Traffic generated by the public network is billed. You can unbind the EIP from your DB instance when the EIP is no longer used.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name to go to the Basic Information page.
  4. In the navigation pane, choose Database Proxy.
  5. Click a proxy instance name to go to the Basic Information page.
  6. In the Proxy Instance Information area, click Bind under Public IP Address (EIP).
  7. In the displayed dialog box, select an EIP and click OK.
    Figure 1 Binding an EIP to a proxy instance
  8. On the Basic Information page, view that the EIP has been bound to the proxy instance.
    To unbind an EIP from the proxy instance, click Unbind under Public IP Address (EIP). In the displayed dialog box, click OK.
    Figure 2 Unbinding an EIP from a proxy instance
