Help Center/ TaurusDB/ User Guide/ Database Proxy (Read/Write Splitting)/ Changing Configurations of a Proxy Instance/ Applying for a Private Domain Name for a Proxy Instance
Updated on 2026-07-16 GMT+08:00
You can use a private network domain name to connect to a proxy instance.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name.
- In the navigation pane, choose Database Proxy.
- Click the name of a proxy instance.
- In the Proxy Instance Information area of the Basic Information page, click Apply under Private Domain Name. Figure 1 Applying for a private domain name
- In the Private Domain Name field, view the generated private domain name.
- Click
- In the Proxy Instance Information area of the Basic Information page, click Change under Private Domain Name.
- In the displayed dialog box, enter a new domain name and click OK.
- Only the prefix of a private domain name can be modified.
- The prefix of a private domain name contains 8 to 63 characters, and can include only lowercase letters and digits.
- The new private domain name must be different from existing ones.
- Click
- In the Proxy Instance Information area of the Basic Information page, click Delete under Private Domain Name.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
