Updated on 2025-12-04 GMT+08:00
Rebooting a Proxy Instance
You can reboot a proxy instance you have created.
  • If the proxy instance status is Abnormal, the reboot may fail.
  • Reboot a proxy instance interrupts the database connection. You are advised to reboot it during off-peak hours. To shorten the time required, reduce database activities during the reboot to reduce rollback of transit transactions.
  1. Log in to the TaurusDB console.
  2. On the Instances page, click the instance name.
  3. In the navigation pane, choose Database Proxy, locate the target proxy instance, and choose More > Reboot in the Operation column.
    Figure 1 Rebooting a proxy instance
  4. In the displayed dialog box, enter RESTART or click Auto Enter, and then click OK.
    Figure 2 Confirming information
  5. Check the reboot progress on the Task Center page. If the task status becomes Completed and the proxy instance status becomes Available, the proxy instance is rebooted successfully.
