Help Center/
TaurusDB/
User Guide/
Database Proxy (Read/Write Splitting)/
Changing Configurations of a Proxy Instance/
Modifying Parameters of a Proxy Instance
Updated on 2026-02-03 GMT+08:00
You can modify parameters of a proxy instance.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name.
- In the navigation pane, choose Database Proxy. Then locate a proxy instance and click its name.
- In the navigation pane, choose Parameters. On the displayed page, modify parameters as required.
You can save, cancel, or preview your modifications.
- To save the modifications, click Save and then click OK.
- To cancel the modifications, click Cancel.
- To preview the modifications, click Preview.
