Changing the Specifications of a Proxy Instance
If the proxy instance specifications cannot meet your workload requirements, you can manually upgrade them. If the instance status changes from Changing proxy specifications to Available, the change is successful.
- The proxy instance specifications can be changed only when your TaurusDB instance, primary node, and read replicas are all running properly.
- A proxy instance cannot be deleted when its CPU and memory specifications are being changed.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the navigation pane, choose Database Proxy.
- On the Database Proxy page, locate the desired proxy instance and choose More > Change Specifications in the Operation column. Figure 1 Changing proxy instance specifications (1)
Alternatively, click the proxy instance name. In the Proxy Instance Information area, click Change under Specifications.
Figure 2 Changing proxy instance specifications (2)
- In the displayed dialog box, select new specifications and click OK. You can reduce or expand the specifications as required.
- View the new specifications on the Database Proxy page.
