Updated on 2025-12-31 GMT+08:00
Exporting a Parameter Template
You can export parameter template details (parameter names, values, and descriptions) of an instance to a custom template or an Excel file for review and analysis.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name.
  4. In the navigation pane, choose Parameters. On the displayed page, click Export above the parameter list.
  5. In the displayed dialog box, set Export To to Custom template or File, enter the template or file name, and click OK.
    The template or file name must start with a letter and consist of 4 to 81 characters. It can contain only letters, digits, hyphens (-), and underscores (_).
    • Custom template: Parameter template details (parameter names, values, and descriptions) of the instance are exported to a new custom template, which will be displayed on the Custom Templates tab of the Parameter Templates page.
    • File: Parameter template details (parameter names, values, and descriptions) of the instance are exported to an Excel file.
    Figure 1 Exporting parameters
