Updated on 2025-12-31 GMT+08:00
Deleting a Parameter Template
You can delete a custom parameter template that is no longer needed.
Precautions
  • Deleted parameter templates cannot be recovered. Exercise caution when performing this operation.
  • Default parameter templates cannot be deleted.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Parameter Templates page, click Custom Templates. Locate the parameter template you want to delete and choose More > Delete in the Operation column.
  4. Click OK.
