Help Center/ TaurusDB/ User Guide/ Parameter Management/ Using a Parameter Template/ Modifying the Description of a Parameter Template
Updated on 2026-07-16 GMT+08:00
You can modify the description of a parameter template you have created.
Precautions
You cannot modify the description of any default parameter template.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Parameter Templates page, click Custom Templates. Locate the parameter template for which you want to edit the description and click in the Description column.
  4. Enter a new description and click OK to submit the modification or Cancel to cancel the modification.
    • After the modification is successful, you can view the new description in the Description column.
    • The description consists of up to 256 characters. It cannot contain carriage returns or any of the following special characters: >!<"&'=
