Updated on 2025-12-31 GMT+08:00
Replicating a Parameter Template
If you already have a parameter template and want to include most of the custom parameters and values from that template in a new parameter template, you can replicate that parameter template. You can also replicate the parameter template to generate a new parameter template for future use.
Precautions
  • After the parameter template is replicated, the new template will be displayed about 5 minutes later.
  • Default parameter templates cannot be replicated, but you can create custom parameter templates based on those default templates.
Replicating a Custom Parameter Template
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Parameter Templates page, click Custom Templates. Locate the parameter template to be replicated and click Replicate in the Operation column.
  4. In the displayed dialog box, set required parameters and click OK.
    Figure 1 Replicating a Custom Parameter Template
    • The template name consists of 1 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.) are allowed.
    • The description consists of up to 256 characters. It cannot contain carriage returns or any of the following special characters:
  5. Check that a new template is generated on the Custom Templates tab.
