Help Center/ TaurusDB/ User Guide/ Parameter Management/ Using a Parameter Template/ Comparing Parameter Templates
Updated on 2025-12-31 GMT+08:00
You can compare instance parameters with a parameter template to see the differences of parameter settings. You can also compare parameter templates to see the differences of parameter settings.
Comparing Parameters or Parameter Templates
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name.
- In the navigation pane, choose Parameters. On the displayed page, click Compare above the parameter list. Figure 1 Comparing instance parameters with those in a specified parameter template
- In the displayed dialog box, select a parameter template and click OK to compare two parameters.
- If their settings are different, the parameter names and values of both parameter templates are displayed.
- If their settings are the same, no data is displayed.
- Click
in the upper left corner and select a region and project. - On the Parameter Templates page, click Default Templates or Custom Templates. Locate a parameter template and click Compare in the Operation column.
- In the displayed dialog box, select a parameter template and click OK. Figure 2 Selecting a parameter template to be compared
- If their settings are the same, no data is displayed. Figure 3 Comparing parameter templates
