Help Center/ TaurusDB/ User Guide/ Security and Encryption/ Changing the Security Group of a DB Instance
Updated on 2025-12-31 GMT+08:00
You can change the security group of an instance.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name to go to the Basic Information page.
  4. In the Instance Information area, click Expand to expand all instance information.
  5. In the Network Information area, click Modify under Security Group.
  6. In the displayed dialog box, select a new security group and click OK.
