Help Center/ TaurusDB/ User Guide/ Data Backups/ Exporting Backup Information
Updated on 2026-07-16 GMT+08:00
You can export backup information of a TaurusDB instance to an Excel file for further analysis. The exported information includes the instance name/ID, backup name/ID, DB engine, backup type, backup time, status, size, and description.
Automated and manual backups cannot be downloaded. Backups of TaurusDB are designed based on Huawei Cloud decoupled storage and compute. Data is backed up based on the minimum storage unit of the Huawei-developed distributed storage pool. After the backup data is downloaded, it cannot be parsed and restored using an open-source tool.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. In the navigation pane, choose Backups.
  4. Select one or more backups and click Export.
    Figure 1 Exporting backup information
    Alternatively, on the Instances page, click the instance name. In the navigation pane, choose Backups. On the Full Backups tab, select one or more backups and click Export.
    Figure 2 Exporting backup information
    • Only the backup information displayed on the current page can be exported.
    • The backup information is exported to an Excel file.
  5. View the exported backup information.
