Updated on 2026-03-19 GMT+08:00
Proxy Instance Kernel Version Release History
Table 1 Proxy instance kernel version release history
Released On
Version
2026-01-30
2.25.12.000
Fixed character set mismatch issues when the session-level connection pool is enabled.
2025-10-30
2.25.09.000
New features:
  • Read/Write splitting is available for SQL statements starting with WITH.
  • When you execute SET SESSION using the Prepare protocol, the statement can be synchronized to read replicas.
2025-07-30
2.25.06.000
  • New feature: PAD_CHAR_TO_FULL_LENGTH SQL mode
  • Fixed issues:
    • Optimized the retry logic for global consistency errors.
    • Optimized the Prepare Close processing logic.
2025-04-30
2.25.03.000
New features:
  • Optimized global consistency performance
  • Automatic request distribution among row store and column store nodes for an HTAP instance
  • Read-only transactions for proxy instances in Read-only (TP) mode
2025-01-21
2.24.12.000
  • New feature: HTAP Standard Edition
  • Fixed issues:
    • Optimized the slow query log processing logic.
    • Optimized binlog pull for proxy instances.
    • Optimized .NET client adaptation.
2024-11-30
2.24.09.020
  • New features:
    • IPv6 for proxy instances
    • Multi-tenancy for TaurusDB instances
  • Fixed issues:
    • Fixed the issue that proxy resource reclamation is slow after SSL is enabled.
    • Fixed the issue that read requests cannot be split after transaction splitting is enabled, set autocommit=0 is used to start a transaction, and commit is used to commit the transaction.
    • Optimized the batch package processing logic.
    • Optimized the resetConnection processing logic.
2024-07-30
2.24.06.000
  • Added binlog pulling through the proxy instance kernel.
  • Fixed the issue that after transaction splitting is enabled, read requests after SELECT FOR UPDATE are sent to the primary node.
2024-05-07
2.24.03.000
Added the feature for assigning requests to row and column store nodes.
2024-01-15
2.23.12.000
  • Added the feature for collecting statistics on slow query logs of proxy instances.
  • Fixed the issue that there is a delay when a proxy instance synchronizes authentication information from the database kernel.
2024-01-04
2.23.09.002
Fixed the logic for proxy instances to retry service SQL statements after the database is faulty.
2023-11-13
2.23.09.001
Fixed the issue that an error is occasionally reported during execution of the prepared SELECT FOR UPDATE statement.
2023-10-20
2.23.09.000
  • New features:
    • Change User protocol
    • Parsing of multiple hints
    • SHOW PROCESSLIST and KILL commands
  • Fixed the issue that the set autocommit setting is synchronized to read replicas after transaction splitting is enabled.
2023-07-31
2.23.06.001
Resolved the increased backend database connections caused by enabling session connection pool.
2023-07-06
2.23.06.000
  • Optimized the performance of the PREPARE STMT protocol again.
2023-06-11
2.23.02.007
Fixed issues:
  • Optimized the performance of the PREPARE STMT protocol.
  • Resolved unexpected traffic allocation of the /* FORCE_SLAVE*/ Hint statement.
2023-04-27
2.23.02.000
Optimized the proxy instance performance.
2022-12-05
2.22.11.000
  • Added multi-statement processing modes.
  • Optimized the error messages reported during SQL statement execution in some scenarios.
2022-09-06
2.22.07.000
  • New features:
    • Session-level connection pooling
    • Dynamic load balancing
  • Optimized the logic for setting session-level transaction isolation levels of proxy instances. By default, the transaction isolation levels are synchronized with those of the database.
2022-06-15
2.7.5.0
Added Application Lossless and Transparent (ALT).
2022-05-06
2.7.4.0
  • New features:
    • A query for more than 16 MB of data
    • Session consistency
  • Optimized how metrics of read-only proxy instances are collected by Cloud Eye.
2022-04-01
2.3.9.8
Added batch execution of prepared statements.
2022-02-09
2.3.9.7
  • New features:
    • Transaction splitting
    • Read-only mode
  • Optimized the execution logic of prepared statements to improve performance.
2021-04-23
2.3.9.0
  • Added proxy instance performance metrics Front-End Connections Created per Second, Transaction Queries per Second, and Multi-Statement Queries per Second.
  • Fixed issues:
    • Optimized the database proxy performance.
    • Fixed traffic congestion occurring when your applications connect to a proxy instance using short connections.
2021-01-14
2.3.8.0
  • Added the feature for obtaining client IP addresses through proxy instances.
  • Fixed issues:
    • Fixed the issue that monitoring data of database proxy is inaccurate.
    • Shortened the downtime of proxy instances during a primary/standby switchover.
2020-10-14
2.3.6.0
Fixed issues:
  • Fixed the issue of connection failures caused by database overload.
  • Improved proxies' compatibility with MySQL protocols.
2020-08-14
2.3.1.0
New features:
  • Maintaining connectivity between clients and database proxies.
  • Monitoring performance metrics of proxy instances.
