Help Center/ TaurusDB/ User Guide/ HTAP Analysis (Standard Edition)/ Lifecycle Management/ Unsubscribing from a Yearly/Monthly Standard HTAP Instance
Updated on 2026-07-16 GMT+08:00
If you do not need a yearly/monthly standard HTAP instance any longer, unsubscribe from it.
  • An instance cannot be unsubscribed when any operations are being performed on it. It can be unsubscribed only after the operations are complete.
  • If a backup of an instance is being restored, the instance cannot be unsubscribed.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
  4. In the navigation pane, choose HTAP Analysis.
  5. Locate an HTAP instance and choose More > Unsubscribe in the Operation column.
  6. In the displayed dialog box, enter DELETE as prompted and click OK.
    Figure 1 Unsubscribing from an HTAP instance
  7. On the page for unsubscribing from resources, confirm the refund information and click Confirm.
  8. After you unsubscribe from an instance order, the instance will be deleted. Check that it is no longer displayed in the HTAP instance list.
