Help Center/
TaurusDB/
User Guide/
HTAP Analysis (Standard Edition)/
Instance Upgrades/
Upgrading the Minor Version of a Standard HTAP Instance
Updated on 2025-08-21 GMT+08:00
You can upgrade the minor version of your standard HTAP instance to improve performance, optimize functions, and fix bugs.
Upgrade Methods
A minor version can be upgraded in either of the following ways:
- Upon submission: The system upgrades the minor version upon your manual submission of the upgrade request.
- In maintenance window: The system upgrades the minor version during the maintenance window you have specified.
- When any new minor version is released, upgrade the minor version of your standard HTAP instance immediately or during the maintenance window.
- The upgrade will cause the standard HTAP instance to reboot and will interrupt services intermittently. To minimize the impact of the upgrade, perform the upgrade during off-peak hours, or ensure that your applications support automatic reconnection.
- A minor version upgrade cannot be rolled back after the upgrade is complete.
- Before upgrading a minor version, check whether there are temporary data synchronization tasks. If there are, wait until the tasks are complete or manually delete the temporary tasks.
Upgrading the Minor Version of a Single Standard HTAP Instance
- Click
in the upper left corner and select a region and project.
- Click
in the upper left corner of the page and choose Databases > TaurusDB.
- On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
- In the navigation pane, choose HTAP Analysis.
- Click the name of an HTAP instance to access the Basic Information page.
- In the DB Instance Information area, click Upgrade next to Kernel Version.
- In the displayed dialog box, select a scheduled time and click OK.
- Upon submission: The system upgrades the minor version immediately after your submission of the upgrade request.
- In maintenance window: The system upgrades the minor version during the maintenance window you have specified. After the operation is complete, on the Task Center page, click Scheduled Tasks and view the information about the upgrade task.
