Viewing Metrics of a Standard HTAP Instance or Nodes
Cloud Eye monitors operating statuses of standard HTAP instances. You can view the metrics of standard HTAP instances on the management console.
- Standard HTAP instances are running properly.
Cloud Eye does not display the metrics of faulty or deleted HTAP instances. When the status of an HTAP instance becomes Available, you can view its metrics.
If an HTAP instance has been faulty for 24 hours, Cloud Eye assumes that the instance no longer exists and deletes it from the monitoring object list. You need to manually clear the alarm rules created for the instance.
Viewing Metrics of an Instance or Node
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
- In the navigation pane, choose HTAP Analysis.
- Locate an HTAP instance and click View Metrics in the Operation column.
Alternatively, click the HTAP instance name. On the displayed Basic Information page, click View Metrics in the upper right corner.
Figure 1 Entry for viewing metrics
- On the displayed Cloud Eye page, view metrics of the HTAP instance. Figure 2 Viewing metrics of an HTAP instance
- Click
- Locate an HTAP instance and click its name to access the Basic Information page.
- In the Node List area, locate a node and click View Metrics in the Operation column.
- View metrics of a FE or BE node.
