Connecting to a Standard HTAP Instance Through DAS
Data Admin Service (DAS) enables you to manage DB instances on a web-based console, simplifying database management and improving working efficiency.
The permission required for remotely connecting to DB instances through DAS has been enabled for you by default. Using DAS to connect to your DB instance is recommended, which is more secure and convenient.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
- In the navigation pane, choose HTAP Analysis.
- In the instance list, locate an HTAP instance and click Log In in the Operation column. Figure 1 Logging in to a standard HTAP instance
- Select the node to be logged in to, enter the database username and password, and click Test Connection.
- After the connection test is successful, click Log In to access your database.
