Updated on 2026-07-16 GMT+08:00
Rebooting a Standard HTAP Instance
You may need to reboot an HTAP instance for maintenance reasons.
  • You can reboot an HTAP instance only when it is available or abnormal. When some operations such as creating a task, changing specifications, scaling up storage, and upgrading a minor version, are being performed on an HTAP instance, the instance cannot be rebooted.
  • It takes about 1 to 2 minutes to reboot an HTAP instance. During the reboot, the instance is unavailable. Rebooting an HTAP instance will clear its cache. To prevent traffic congestion during peak hours, you are advised to reboot it during off-peak hours.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
  4. In the navigation pane, choose HTAP Analysis.
  5. Locate an HTAP instance and choose More > Reboot in the Operation column.
  6. In the displayed dialog box, click OK.
    Figure 1 Rebooting an HTAP instance
  7. Check that the standard HTAP instance status changes from Rebooting to Available.
