Help Center/ TaurusDB/ User Guide/ Parameter Management/ Introducing the High-Performance Parameter Template
Updated on 2025-04-22 GMT+08:00
To improve database performance, TaurusDB provides a high-performance parameter template. You can select this template when buying an instance.
This section explains the parameter settings in the high-performance parameter template and how the template enhances performance.
Introduction
The high-performance parameter template is a set of optimized configuration parameters that aim to enhance the performance and reliability of database servers. The parameter settings in the template can be adjusted based on different application scenarios and hardware configurations.
The parameters in the high-performance parameter template are as follows.
Table 1 Parameter description
Value in the High-Performance Template
Value in the Default Template
innodb_flush_log_at_trx_commit
If this parameter is set to 0, logs are not flushed to disks when transactions are committed. Instead, they are only flushed once per second or when the log buffer (innodb_log_buffer_size) is full. This provides low durability but high performance.
0
rds_plan_cache
If this parameter is set to ON, an execution plan is cached. The next time the same query is executed, the cached execution plan can be reused, which improves the database's query performance.
ON
OFF
Application Scenarios and Potential Risks
Generally, the high-performance parameter template can improve database performance. However, it should be adjusted based on specific application scenarios and hardware configurations.
While the template is designed to enhance performance and reliability of database servers, it does come with some risks during database usage.
  • Setting innodb_flush_log_at_trx_commit to 0 can improve low-concurrency write performance, but in extreme cases, it may result in data loss of up to one second.
  • Setting rds_plan_cache to ON can improve query performance because the execution plan of a PREPARE statement is cached and the optimizer does not need to generate an execution plan again. However, it may not be effective in all read/write scenarios.
The kernel version of your TaurusDB instance must be 2.0.51.240300 or later. For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
Usage
You can select the high-performance parameter template when buying an instance.
Figure 1 Selecting the high-performance parameter template
Performance Comparison
Test environment:
  • TaurusDB instance specifications: Dedicated, 8 vCPUs | 32 GB
  • Kernel version: 2.0.51.240300
Sysbench test process:
  • Test scenarios: read-only, write-only, and read/write
  • Data volume: 250 tables x 25,000 rows of data in read-only scenarios, 250 tables x 25,000 rows of data in write-only scenarios, and 25 tables x 250,000 rows of data in read/write scenarios
  • Performance metric: queries per second (QPS) in 1, 2, 4, 8, 16, 32, 64, 128, and 256 concurrent requests. QPS indicates the number of SQL statements executed by the database per second.
Test results:
  • Read-only model
  • Write-only model
  • Read/Write model
Conclusion: The preceding sysbench test results show that the high-performance parameter template significantly improves the database performance.
