- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
Kernel
- TaurusDB Kernel Version Release History
Common Kernel Functions
- Parallel Query
- Near Data Processing
- DDL Optimization
- Fast Binlog Positioning
- Backward Index Scan
- Statement Outline
- Idle Transaction Disconnection
- LIMIT...OFFSET Pushdown
- Conversion of IN Predicates Into Subqueries
- DISTINCT Optimization for Multi-Table Joins
- Diagnosis on Large Transactions
- Enhanced Partitioned Tables
- Hot Row Update
- Multi-tenancy
- Column Compression
- Table Recycle Bin
- Cold Data Preloading for Read Replicas
- Self-Healing of Read Replicas upon a Replication Latency
User Guide
- Permissions Management
- Buying a DB Instance
- Connecting to a DB Instance
- Database Usage
- Data Migration
Instance Management
- Viewing the Overall Status of DB Instances
- Viewing Metrics
- Instance Lifecycle Management
Configuration Changes
- Changing the vCPUs and Memory of a DB Instance or Node
- Changing the Storage Space of a DB Instance
- Configuring Auto Scaling Policies for a DB Instance
- Changing the Maintenance Window of a DB Instance
- Customizing Displayed Items of the Instance List
- Upgrading the Minor Version of a DB Instance
- Enabling or Disabling Event Scheduler
- Updating the OS of a DB Instance
- Data Backups
- Data Restorations
- Serverless Instances
- Multi-primary Instances (OBT)
- Read Replicas
Database Proxy (Read/Write Splitting)
- What Is Database Proxy?
- Creating a Proxy Instance for Read/Write Splitting
Changing Configurations of a Proxy Instance
- Changing the Consistency Level of a Proxy Instance
- Enabling the Connection Pool for a Proxy Instance
- Enabling Transaction Splitting for a Proxy Instance
- Modifying the Routing Policy of a Proxy Instance
- Changing Read Weights of Nodes
- Changing the Multi-statement Processing Mode of a Proxy Instance
- Enabling Automatic Association of New Nodes with a Proxy Instance
- Enabling Access Control for a Proxy Instance
- Changing the Specifications of a Proxy Instance
- Changing the Number of Nodes for a Proxy Instance
- Applying for a Private Domain Name for a Proxy Instance
- Changing the Port of a Proxy Instance
- Changing the Proxy Address of a Proxy Instance
- Modifying Parameters of a Proxy Instance
- Binding an EIP to a Proxy Instance
- Proxy Instance Lifecycle
- Proxy Instance Kernel Versions
- Using Hints for Read/Write Splitting
- DBA Assistant
- Parameter Management
- Security and Encryption
- Cold and Hot Data Separation (OBT)
- Application Lossless and Transparent (ALT)
HTAP Analysis (Standard Edition)
- What Is HTAP of Standard Edition?
- Connecting to an HTAP Instance for Complex OLAP Queries
- Connecting to a Standard HTAP Instance
Standard HTAP Instance Management
- Rebooting a Standard HTAP Instance
- Rebooting a Node of a Standard HTAP Instance
- Changing Storage Space of a Standard HTAP Instance
- Adding Read Replicas to a Standard HTAP Instance
- Deleting a Standard HTAP Instance
- Adjusting Blacklisted or Whitelisted Tables of a Standard HTAP Instance and Repairing Tables
- Standard HTAP Account Management
- Viewing Metrics of a Standard HTAP Instance or Nodes
- Syntax and Data Type Mappings Between HTAP and TaurusDB Instances
- Performance Tuning
RegionlessDB Clusters (OBT)
- What Is a RegionlessDB Cluster?
- Using a RegionlessDB Cluster for Remote Multi-Active DR
- Using a RegionlessDB Cluster for Remote DR
- Performing a Primary/Standby Switchover or Failover in a RegionlessDB Cluster
- Removing a Standby Instance from a RegionlessDB Cluster
- Deleting a RegionlessDB Cluster
- Viewing the Replication Latency and Traffic of a RegionlessDB Cluster
- Monitoring and Alarms
- Logs and Auditing
- Task Center
- Tag Management
- Quota Management
- Best Practices
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
- DB Engine Version Queries
- Database Specification Queries
Instance Management
- Creating a DB Instance
- Rebooting a DB Instance
- Deleting/Unsubscribing from a DB Instance
- Creating a Read Replica
- Deleting or Unsubscribing from a Read Replica
- Scaling up Storage of a Yearly/Monthly DB Instance
- Changing a DB Instance Name
- Resetting a Database Password
- Changing DB Instance Specifications
- Querying Dedicated Resource Pools
- Querying Dedicated Resources
- Configuring the Monitoring By Seconds Function
- Querying the Configuration of Monitoring by Seconds
- Rebooting a Node
- Upgrading the Kernel Version of a DB Instance
- Enabling or Disabling SSL
- Binding an EIP
- Unbinding an EIP
- Promoting a Read Replica to Primary
- Changing a Maintenance Window
- Changing a Security Group
- Changing a Private IP Address
- Changing a Database Port
- Changing a DB Instance Description
- Changing a Private Domain Name
- Querying the Kernel Version
- Modifying Auto Scaling Policies
- Querying Auto Scaling Policies
- Pre-Checking Resources
- Querying DB instances
- Querying Details of a DB Instance
- Querying Details of DB Instances in Batches
- Modifying a Recycling Policy
- Querying a Recycling Policy
- Querying Instances in the Recycle Bin
- Changing Node Names in Batches
- Querying Historical Records of Auto Scaling
- Setting a Policy for a Serverless DB Instance
- Changing the Failover Priority of a Read Replica
- Querying an EIP
Backup Management
- Configuring a Same-Region Backup Policy
- Creating a Manual Backup
- Querying Full Backups
- Querying an Automated Backup Policy
- Deleting a Manual Backup
- Restoring Data to the Original Instance or an Existing Instance
- Querying the Restoration Time Range
- Enabling or Disabling Encrypted Backup
- Checking Whether Encrypted Backup Is Enabled
- Querying Incremental Backups
- Configuring a Cross-Region Backup Policy
- Restoring Tables to a Specified Point in Time
- Querying Tables for Table-level Point-in-Time Recovery
Parameter Template Management
- Querying Parameter Templates
- Creating a Parameter Template
- Deleting a Parameter Template
- Obtaining Details About a Parameter Template
- Modifying Parameters in a Parameter Template
- Applying a Parameter Template
- Replicating a Parameter Template
- Comparing Parameter Templates
- Querying Instances That a Parameter Template Can Be Applied To
- Viewing Parameter Change History
- Obtaining Parameter Information of a Specified DB Instance
- Modifying Parameters of a Specified DB Instance
- Replicating the Parameter Template of a DB Instance
- Querying Application Records of a Parameter Template
- Quota Management
Database Proxy
- Deleting a Proxy Instance
- Querying Proxy Instances
- Querying Proxy Instance Specifications
- Adding Proxy Nodes
- Deleting Proxy Nodes
- Assigning Read Weights
- Changing the Routing Policy of a Proxy Instance
- Enabling or Disabling Transaction Splitting for a Proxy Instance
- Enabling or Disabling Automatic Association of New Nodes with Proxy Instances
- Changing Session Consistency of a Proxy Instance
- Changing the Connection Pool Type of a Proxy Instance
- Upgrading the Kernel Version of a Proxy Instance
- Modifying the Name of a Proxy Instance
- Querying Access Control Settings of a Proxy Instance
- Querying the Minor Version of a Proxy Instance
- Querying Kernel Parameters of a Proxy Instance
- Enabling or Disabling Access Control
- Configuring Access Control Rules
- Enabling or Disabling SSL for a Proxy Instance
- Rebooting a Proxy Instance
Log Management
- Enabling or Disabling SQL Explorer
- Querying Whether SQL Explorer Is Enabled
- Querying Slow Query Logs
- Querying Error Logs
- Obtaining the Temporary Link for Downloading Full SQL
- Querying LTS Configurations of an Instance
- Deleting LTS Configurations in Batches
- Creating LTS Configurations in Batches
- Querying Whether Show Original Log Is Enabled
- Enabling or Disabling Show Original Log
- Querying Slow Query Log Statistics
- Obtaining Links for Downloading Slow Query Logs
- Tag Management
- Database User Management
- Database Management
- Traffic Management
- Task Center
- Intelligent Diagnosis
HTAP (Standard Edition)
- Restoring a Data Synchronization Task for a StarRocks Instance
- Stopping a Data Synchronization Task for a StarRocks Instance
- Checking Table Configurations for HTAP Data Synchronization
- Creating a StarRocks Instance
- Querying a StarRocks Instance
- Deleting a StarRocks Instance
- Rebooting a StarRocks Instance
- Rebooting a StarRocks Node
- Checking StarRocks Resources
- Querying HTAP Engine Resources
- Obtaining the Storage Type of an HTAP Instance
- Querying Specifications of an HTAP Instance
- Querying HTAP Instances
- Creating a Data Synchronization Task for a StarRocks Instance
- Deleting a Data Synchronization Task for a StarRocks Instance
- Querying Data Synchronization Tasks of a StarRocks Instance
- Checking Database Configurations for HTAP Data Synchronization
- Querying Configurations of a StarRocks Data Synchronization Task
- Querying Database Parameter Settings for StarRocks Data Synchronization
- Querying Databases of a StarRocks Instance
- Querying Database Accounts
- Creating a Database Account
- Deleting a Database Account
- Changing the Password of a Database Account
- Changing Permissions of a Database Account
- Changing the Specifications of a StarRocks Instance
- Querying Parameters
- Enabling Assign Requests to Row and Column Store Nodes for a StarRocks Instance
- Comparing Parameters
- Upgrading the Kernel Version of a StarRocks Instance
- Multi-tenancy
APIs (Unavailable Soon)
Instance Management
- Querying DB Instances
- Deleting a DB Instance
- Deleting a Read Replica
- Modifying DB Instance Specifications
- Backup Management
- Parameter Template Management
- Quota Management
- Database Proxy
- Log Management
- Task Information Queries
- Appendix
- SDK Reference
- Product Consulting
- Resource Freezing, Unfreezing, Release, Deletion, and Unsubscription
Database Connections
- What Should I Do If I Can't Connect to My TaurusDB Instance?
- What Should I Do If an ECS Can't Connect to a TaurusDB Instance?
- Can an External Server Access a TaurusDB Instance?
- What Is the Maximum Number of Connections to a TaurusDB Instance?
- What Do I Do If There Are Too Many Database Connections?
- Are There Any Risks If There Are Too Many Connections to a TaurusDB Instance?
- What Should I Do If the Network Connectivity Test Fails?
- Can I Access a TaurusDB Instance over an Intranet Connection Across Regions?
- How Do I Check the Connections to a TaurusDB Instance?
- How Do I Enable Availability Detection for a Connection Pool in the Service Code?
- Client Installation
- Database Migration
- Database Permissions
Database Performance
- What Should I Do If the CPU Usage of My TaurusDB Instance Is High?
- How Do I Handle Slow SQL Statements Caused by Inappropriate Composite Index Settings?
- How Do I Handle a Large Number of Temporary Tables Being Generated for Long Transactions and High Memory Usage?
- What Should I Do If Locks on Long Transactions Block the Execution of Subsequent Transactions?
- How Can I Use Temporary Disks of TaurusDB?
- What Is the CPU Usage of a TaurusDB Instance with Empty Load?
Database Usage
- Why Are the Results Inconsistent After the MATCH AGAINST Statement Is Executed, Respectively, on Primary Nods and Read Replicas?
- How Do I Add Columns Using INSTANT?
- How Do I Use LOAD DATA to Import Local Data?
- How Do I Write Data to or Create Indexes for an Ultra-large Table?
- What Are the Risks of Deleting an Index from an Ultra-large Table?
- Backups
Database Parameter Modification
- How Do I Change the Time Zone of a TaurusDB Instance?
- How Do I Configure a Password Expiration Policy for TaurusDB Instances?
- How Do I Ensure that the Database Character Set of a TaurusDB Instance Is Correct?
- How Do I Use the utf8mb4 Character Set to Store Emojis in a TaurusDB Instance?
- How Do I Set Case Sensitivity for TaurusDB Table Names?
- Can I Use SQL Commands to Modify Global Parameters of My TaurusDB Instance?
- Network Security
Log Management
- Can I Enable general_log for TaurusDB?
- How Do I View All SQL Statements Executed by TaurusDB?
- How Do I Enable and View Binlog of My TaurusDB Instance?
- How Do I Change the Binlog Retention Period?
- How Do I View Deadlock Logs of TaurusDB?
- Why Are Slow SQL Statements Displayed in Slow Query Log Monitoring, but No Information About Them Is Displayed on the Slow Query Logs Tab Page in the Logs Module?
- Version Upgrade
Troubleshooting
Backup and Restoration Issues
- Insufficient Permissions During Data Export Using mysqldump
- How Do I use mysqlbinlog to Obtain Binlog Files?
- Canal Fails to Parse Binlogs
- Precautions for Exporting Large Tables Through mysqldump
- Commands for Exporting Data Through mysqldump
- System Inaccessible After Field Addition to a Database Table
- SQL Statements Such as SET @@SESSION.SQL_LOG_BIN Displayed After You Run mysqldump
- Insufficient Privileges Reported for Canal
Connection Issues
- Login Failed After ssl_type of root Is Changed to ANY
- Failed to Connect to a DB Instance Using SSL
- Description of Each IP Address
- SSL Connection Failed Due to Inconsistent TLS Versions
- Error Message "connection established slowly"
- "Access denied" Displayed During Database Connection
- Failed to Connect to a Database Using mariadb-connector in SSL Mode
- Failed to Connect to a Database as User root
- Client Automatically Disconnected from a DB Instance
- Disconnection Occurs Every 45 Days Due to the istio-citadel Certificate Mechanism
SQL Issues
- Invalid TIMESTAMP Default Value during Table Creation
- Failed to Change the VARCHAR Length Due to the Index Length Limit
- Slow SQL Queries After a Large Amount of Data Is Deleted from a Large Table
- Error 1366 Reported When Data Containing Emojis Is Updated
- Slow Stored Procedure Execution Due to Inconsistent Collations
- ERROR [1412] Reported for a DB Instance
- Failed to Delete a Table with a Foreign Key
- Incorrect GROUP_CONCAT Results
- Error Message "Too many keys specified" Displayed When a Secondary Index Is Created
- DISTINCT and GROUP BY Optimization
- Equivalent Comparison Failures with Floating-Point Numbers
- A Large Number of SELECT Requests Routed to The Primary Instance After Database Proxy Is Enabled
- Tablespace Bloat
- ERROR 1396 Reported When a User Is Created
- Error Message Reported When alter table xxx discard/import tablespace Is Executed
- Native Error 1461 Reported by a DB Instance
- "Row size too large" Reported When a Table Failed to Be Created
- Duplicate Data Exists After ORDER BY LIMIT Is Executed
- Error Message Reported When select * from sys.innodb_lock_waits Is Executed
- Parameter-related Issues
Performance Issues
- High CPU Usage
- Out of Memory (OOM) Errors
- Tablespace Bloat
- Read Replica Uses Far More Storage Than the Primary Node
- Slow SQL Execution Due to Hot and Cold Data Problems
- Full Storage Caused by Complex Queries
- Slow Response Due to Deadlocks
- CPU Usage Increase
- CPU Resource Exhaustion Caused by Too Many Concurrent Slow Queries
Basic Issues
- How Do I View the Used Storage of My TaurusDB Instance?
- Renaming Databases and Tables
- Character Set and Collation Settings
- Auto-Increment Field Value Jump
- Starting Value and Increment of AUTO_INCREMENT
- Changing the AUTO_INCREMENT Value of a Table
- Failed to Insert Data Because Values for the Auto-increment Primary Key Field Reach the Upper Limit
- Auto-increment Field Values
- AUTO_INCREMENT Not Displayed in the Table Structure
- Impact of Creating an Empty Username
- No Scanned Rows Recorded in Slow Query Logs
- "handle_sync_msg_from_slave my_net_read error:-1" Displayed on the Error Logs Tab Page
- ERROR 1290 (HY000): The MySQL server is running with the --sql-replica-on option so it cannot execute this statement
- Videos
Show all
Events Supported by Event Monitoring
Event Source |
Event Name |
Event ID |
Alarm Severity |
Description |
Handling Suggestion |
Impact |
TaurusDB |
Incremental backup failure |
TaurusIncrementalBackupInstanceFailed |
Major |
The network between the instance and the management plane or the OBS is disconnected, or the backup environment created for the instance is abnormal. |
Backup jobs fail. |
Read replica creation failure |
addReadonlyNodesFailed |
Major |
The quota is insufficient or underlying resources are exhausted. |
Check the read replica quota. Release resources and create read replicas again. |
Read replicas fail to be created. |
DB instance creation failure |
createInstanceFailed |
Major |
Check the instance quota. Release resources and create instances again. |
Instances fail to be created. |
Read replica promotion failure |
activeStandBySwitchFailed |
Major |
The read replica fails to be promoted to the primary node due to network or server failures. The original primary node takes over services quickly. |
The read replica fails to be promoted to the primary node. |
Instance specifications change failure |
flavorAlterationFailed |
Major |
Instance specifications fail to be changed. |
Faulty DB instance |
TaurusInstanceRunningStatusAbnormal |
Major |
The instance process is faulty or the network between the instance and the DFV storage is disconnected. |
Services may be affected. |
DB instance recovered |
TaurusInstanceRunningStatusRecovered |
Major |
The instance is recovered. |
Observe the service running status. |
None. |
Faulty node |
TaurusNodeRunningStatusAbnormal |
Major |
The node process is faulty or the network between the node and the DFV storage is disconnected. |
Observe the instance and service running statuses. |
A read replica may be promoted to the primary node. |
Node recovered |
TaurusNodeRunningStatusRecovered |
Major |
The node is recovered. |
View the node running status. |
None. |
Read replica deletion failure |
TaurusDeleteReadOnlyNodeFailed |
Major |
The network between the management plane and the read replica is disconnected or the VM fails to be deleted from IaaS. |
Read replicas fail to be deleted. |
Password reset failure |
TaurusResetInstancePasswordFailed |
Major |
The network between the management plane and the instance is disconnected or the instance is abnormal. |
Check the instance status and try again. If the fault persists, submit a service ticket. |
Passwords fail to be reset for instances. |
DB instance reboot failure |
TaurusRestartInstanceFailed |
Major |
Instances fail to be rebooted. |
Restoration to new DB instance failure |
TaurusRestoreToNewInstanceFailed |
Major |
The instance quota is insufficient, underlying resources are exhausted, or the data restoration logic is incorrect. |
If the new instance fails to be created, check the instance quota, release resources, and try to restore to a new instance again. In other cases, submit a service ticket. |
Backup data fails to be restored to new instances. |
EIP binding failure |
TaurusBindEIPToInstanceFailed |
Major |
The binding task fails. |
EIPs fail to be bound to instances. |
EIP unbinding failure |
TaurusUnbindEIPFromInstanceFailed |
Major |
The unbinding task fails. |
EIPs fail to be unbound from instances. |
Parameter modification failure |
TaurusUpdateInstanceParameterFailed |
Major |
Instance parameters fail to be modified. |
Parameter template application failure |
TaurusApplyParameterGroupToInstanceFailed |
Major |
The network between the management plane and instances is disconnected or the instances are abnormal. |
Parameter templates fail to be applied to instances. |
Full backup failure |
TaurusBackupInstanceFailed |
Major |
Backup jobs fail. |
Read replica promotion |
TaurusActiveStandbySwitched |
Major |
When the primary node is faulty, a read replica is promoted to the primary node. |
Check the instance status. If the fault persists, submit a service ticket. |
Services are intermittently interrupted. |
Instance read-only |
NodeReadonlyMode |
Major |
The instance supports only query operations. |
After the instance becomes read-only, write requests cannot be processed. |
Instance read/write |
NodeReadWriteMode |
Major |
The instance can process both write and read requests. |
None. |
Instance DR switchover |
DisasterSwitchOver |
Major |
If an instance is faulty and unavailable, a switchover is performed to ensure that the instance continues to provide services. |
The database connection is intermittently interrupted. The DR instance is promoted to primary to provide services. |
Database process restarted |
TaurusDatabaseProcessRestarted |
Major |
The database process is stopped due to insufficient memory or high load. |
Log in to the Cloud Eye console. Check whether the memory usage increases sharply or the CPU usage is too high for a long time. You can increase the specifications or optimize the service logic. |
When the database process is suspended, workloads on the node are interrupted. In this case, the HA service automatically restarts the database process and attempts to recover the workloads. |
Connection failure between proxy instance and DB instance |
proxy_connection_failure_to_db |
Major |
The database proxy failed to establish a new connection with the primary node of a DB instance, and it may fail to establish a new connection with a read replica. The DB instance or proxy instance is overloaded, or the network between the them is abnormal. |
Change values of related parameters based on metrics (Connections, Active Connections, and CPU Usage) of the DB instance and proxy instance. If the metrics are normal, submit a service ticket. |
Service requests accessed through the proxy instance are interrupted. |
Connection failure between database proxy and read replica |
proxy_connection_failure_to_replica |
General |
The proxy instance failed to establish a new connection with a read replica. The read replica is overloaded, or the network between the proxy instance and read replica is abnormal. |
Change values of related parameters based on metrics (Connections, Active Connections, and CPU Usage) of the read replica. If the metrics are normal, submit a service ticket. |
Read requests accessed through the proxy instance are interrupted. |
Proxy instance access to DB instance failure |
proxy_connection_failure_cause_security_group |
Major |
No rules in the security group allow the proxy instance to access the DB instance. |
Add the proxy instance address to the rules of the security group. |
