Updated on 2025-12-31 GMT+08:00
Viewing Event Monitoring Data
In event monitoring, you can query system events that are automatically reported to Cloud Eye and custom events reported to Cloud Eye through the API. You can create alarm rules for both system events and custom events. When specific events occur, Cloud Eye generates alarms for you.
Event monitoring is enabled by default.
You can view the event monitoring data.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, locate the DB instance and click View Metrics in the Operation column to go to the Cloud Eye console.
    Alternatively, go to the Cloud Eye console using either of the following methods:
    • On the Instances page, click the instance name to go to the Basic Information page. In the upper right corner of the page, click and choose View Metrics.
    • In the Node List area of the Basic Information page, locate a node and click View Metrics in the Operation column.
  4. Click to return to the Cloud Eye console.
  5. In the navigation pane, choose Event Monitoring.
    On the displayed Event Monitoring page, all system events of the last 24 hours are displayed by default.
    You can also click 1h, 3h, 12h, 1d, 7d, or 30d to view events generated in different periods.
  6. Locate an event and click View Event in the Operation column to view details about a specific event.
