- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
Kernel
- TaurusDB Kernel Version Release History
Common Kernel Functions
- Parallel Query
- Near Data Processing
- DDL Optimization
- Fast Binlog Positioning
- Backward Index Scan
- Statement Outline
- Idle Transaction Disconnection
- LIMIT...OFFSET Pushdown
- Conversion of IN Predicates Into Subqueries
- DISTINCT Optimization for Multi-Table Joins
- Diagnosis on Large Transactions
- Enhanced Partitioned Tables
- Hot Row Update
- Multi-tenancy
- Column Compression
- Table Recycle Bin
- Cold Data Preloading for Read Replicas
- Self-Healing of Read Replicas upon a Replication Latency
User Guide
- Permissions Management
- Buying a DB Instance
- Connecting to a DB Instance
- Database Usage
- Data Migration
Instance Management
- Viewing the Overall Status of DB Instances
- Viewing Metrics
- Instance Lifecycle Management
Configuration Changes
- Changing the vCPUs and Memory of a DB Instance or Node
- Changing the Storage Space of a DB Instance
- Configuring Auto Scaling Policies for a DB Instance
- Changing the Maintenance Window of a DB Instance
- Customizing Displayed Items of the Instance List
- Upgrading the Minor Version of a DB Instance
- Enabling or Disabling Event Scheduler
- Updating the OS of a DB Instance
- Data Backups
- Data Restorations
- Serverless Instances
- Multi-primary Instances (OBT)
- Read Replicas
Database Proxy (Read/Write Splitting)
- What Is Database Proxy?
- Creating a Proxy Instance for Read/Write Splitting
Changing Configurations of a Proxy Instance
- Changing the Consistency Level of a Proxy Instance
- Enabling the Connection Pool for a Proxy Instance
- Enabling Transaction Splitting for a Proxy Instance
- Modifying the Routing Policy of a Proxy Instance
- Changing Read Weights of Nodes
- Changing the Multi-statement Processing Mode of a Proxy Instance
- Enabling Automatic Association of New Nodes with a Proxy Instance
- Enabling Access Control for a Proxy Instance
- Changing the Specifications of a Proxy Instance
- Changing the Number of Nodes for a Proxy Instance
- Applying for a Private Domain Name for a Proxy Instance
- Changing the Port of a Proxy Instance
- Changing the Proxy Address of a Proxy Instance
- Modifying Parameters of a Proxy Instance
- Binding an EIP to a Proxy Instance
- Proxy Instance Lifecycle
- Proxy Instance Kernel Versions
- Using Hints for Read/Write Splitting
- DBA Assistant
- Parameter Management
- Security and Encryption
- Cold and Hot Data Separation (OBT)
- Application Lossless and Transparent (ALT)
HTAP Analysis (Standard Edition)
- What Is HTAP of Standard Edition?
- Connecting to an HTAP Instance for Complex OLAP Queries
- Connecting to a Standard HTAP Instance
Standard HTAP Instance Management
- Rebooting a Standard HTAP Instance
- Rebooting a Node of a Standard HTAP Instance
- Changing Storage Space of a Standard HTAP Instance
- Adding Read Replicas to a Standard HTAP Instance
- Deleting a Standard HTAP Instance
- Adjusting Blacklisted or Whitelisted Tables of a Standard HTAP Instance and Repairing Tables
- Standard HTAP Account Management
- Viewing Metrics of a Standard HTAP Instance or Nodes
- Syntax and Data Type Mappings Between HTAP and TaurusDB Instances
- Performance Tuning
RegionlessDB Clusters (OBT)
- What Is a RegionlessDB Cluster?
- Using a RegionlessDB Cluster for Remote Multi-Active DR
- Using a RegionlessDB Cluster for Remote DR
- Performing a Primary/Standby Switchover or Failover in a RegionlessDB Cluster
- Removing a Standby Instance from a RegionlessDB Cluster
- Deleting a RegionlessDB Cluster
- Viewing the Replication Latency and Traffic of a RegionlessDB Cluster
- Monitoring and Alarms
- Logs and Auditing
- Task Center
- Tag Management
- Quota Management
- Best Practices
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
- DB Engine Version Queries
- Database Specification Queries
Instance Management
- Creating a DB Instance
- Rebooting a DB Instance
- Deleting/Unsubscribing from a DB Instance
- Creating a Read Replica
- Deleting or Unsubscribing from a Read Replica
- Scaling up Storage of a Yearly/Monthly DB Instance
- Changing a DB Instance Name
- Resetting a Database Password
- Changing DB Instance Specifications
- Querying Dedicated Resource Pools
- Querying Dedicated Resources
- Configuring the Monitoring By Seconds Function
- Querying the Configuration of Monitoring by Seconds
- Rebooting a Node
- Upgrading the Kernel Version of a DB Instance
- Enabling or Disabling SSL
- Binding an EIP
- Unbinding an EIP
- Promoting a Read Replica to Primary
- Changing a Maintenance Window
- Changing a Security Group
- Changing a Private IP Address
- Changing a Database Port
- Changing a DB Instance Description
- Changing a Private Domain Name
- Querying the Kernel Version
- Modifying Auto Scaling Policies
- Querying Auto Scaling Policies
- Pre-Checking Resources
- Querying DB instances
- Querying Details of a DB Instance
- Querying Details of DB Instances in Batches
- Modifying a Recycling Policy
- Querying a Recycling Policy
- Querying Instances in the Recycle Bin
- Changing Node Names in Batches
- Querying Historical Records of Auto Scaling
- Setting a Policy for a Serverless DB Instance
- Changing the Failover Priority of a Read Replica
- Querying an EIP
Backup Management
- Configuring a Same-Region Backup Policy
- Creating a Manual Backup
- Querying Full Backups
- Querying an Automated Backup Policy
- Deleting a Manual Backup
- Restoring Data to the Original Instance or an Existing Instance
- Querying the Restoration Time Range
- Enabling or Disabling Encrypted Backup
- Checking Whether Encrypted Backup Is Enabled
- Querying Incremental Backups
- Configuring a Cross-Region Backup Policy
- Restoring Tables to a Specified Point in Time
- Querying Tables for Table-level Point-in-Time Recovery
Parameter Template Management
- Querying Parameter Templates
- Creating a Parameter Template
- Deleting a Parameter Template
- Obtaining Details About a Parameter Template
- Modifying Parameters in a Parameter Template
- Applying a Parameter Template
- Replicating a Parameter Template
- Comparing Parameter Templates
- Querying Instances That a Parameter Template Can Be Applied To
- Viewing Parameter Change History
- Obtaining Parameter Information of a Specified DB Instance
- Modifying Parameters of a Specified DB Instance
- Replicating the Parameter Template of a DB Instance
- Querying Application Records of a Parameter Template
- Quota Management
Database Proxy
- Deleting a Proxy Instance
- Querying Proxy Instances
- Querying Proxy Instance Specifications
- Adding Proxy Nodes
- Deleting Proxy Nodes
- Assigning Read Weights
- Changing the Routing Policy of a Proxy Instance
- Enabling or Disabling Transaction Splitting for a Proxy Instance
- Enabling or Disabling Automatic Association of New Nodes with Proxy Instances
- Changing Session Consistency of a Proxy Instance
- Changing the Connection Pool Type of a Proxy Instance
- Upgrading the Kernel Version of a Proxy Instance
- Modifying the Name of a Proxy Instance
- Querying Access Control Settings of a Proxy Instance
- Querying the Minor Version of a Proxy Instance
- Querying Kernel Parameters of a Proxy Instance
- Enabling or Disabling Access Control
- Configuring Access Control Rules
- Enabling or Disabling SSL for a Proxy Instance
- Rebooting a Proxy Instance
Log Management
- Enabling or Disabling SQL Explorer
- Querying Whether SQL Explorer Is Enabled
- Querying Slow Query Logs
- Querying Error Logs
- Obtaining the Temporary Link for Downloading Full SQL
- Querying LTS Configurations of an Instance
- Deleting LTS Configurations in Batches
- Creating LTS Configurations in Batches
- Querying Whether Show Original Log Is Enabled
- Enabling or Disabling Show Original Log
- Querying Slow Query Log Statistics
- Obtaining Links for Downloading Slow Query Logs
- Tag Management
- Database User Management
- Database Management
- Traffic Management
- Task Center
- Intelligent Diagnosis
HTAP (Standard Edition)
- Restoring a Data Synchronization Task for a StarRocks Instance
- Stopping a Data Synchronization Task for a StarRocks Instance
- Checking Table Configurations for HTAP Data Synchronization
- Creating a StarRocks Instance
- Querying a StarRocks Instance
- Deleting a StarRocks Instance
- Rebooting a StarRocks Instance
- Rebooting a StarRocks Node
- Checking StarRocks Resources
- Querying HTAP Engine Resources
- Obtaining the Storage Type of an HTAP Instance
- Querying Specifications of an HTAP Instance
- Querying HTAP Instances
- Creating a Data Synchronization Task for a StarRocks Instance
- Deleting a Data Synchronization Task for a StarRocks Instance
- Querying Data Synchronization Tasks of a StarRocks Instance
- Checking Database Configurations for HTAP Data Synchronization
- Querying Configurations of a StarRocks Data Synchronization Task
- Querying Database Parameter Settings for StarRocks Data Synchronization
- Querying Databases of a StarRocks Instance
- Querying Database Accounts
- Creating a Database Account
- Deleting a Database Account
- Changing the Password of a Database Account
- Changing Permissions of a Database Account
- Changing the Specifications of a StarRocks Instance
- Querying Parameters
- Enabling Assign Requests to Row and Column Store Nodes for a StarRocks Instance
- Comparing Parameters
- Upgrading the Kernel Version of a StarRocks Instance
- Multi-tenancy
APIs (Unavailable Soon)
Instance Management
- Querying DB Instances
- Deleting a DB Instance
- Deleting a Read Replica
- Modifying DB Instance Specifications
- Backup Management
- Parameter Template Management
- Quota Management
- Database Proxy
- Log Management
- Task Information Queries
- Appendix
- SDK Reference
- Product Consulting
- Resource Freezing, Unfreezing, Release, Deletion, and Unsubscription
Database Connections
- What Should I Do If I Can't Connect to My TaurusDB Instance?
- What Should I Do If an ECS Can't Connect to a TaurusDB Instance?
- Can an External Server Access a TaurusDB Instance?
- What Is the Maximum Number of Connections to a TaurusDB Instance?
- What Do I Do If There Are Too Many Database Connections?
- Are There Any Risks If There Are Too Many Connections to a TaurusDB Instance?
- What Should I Do If the Network Connectivity Test Fails?
- Can I Access a TaurusDB Instance over an Intranet Connection Across Regions?
- How Do I Check the Connections to a TaurusDB Instance?
- How Do I Enable Availability Detection for a Connection Pool in the Service Code?
- Client Installation
- Database Migration
- Database Permissions
Database Performance
- What Should I Do If the CPU Usage of My TaurusDB Instance Is High?
- How Do I Handle Slow SQL Statements Caused by Inappropriate Composite Index Settings?
- How Do I Handle a Large Number of Temporary Tables Being Generated for Long Transactions and High Memory Usage?
- What Should I Do If Locks on Long Transactions Block the Execution of Subsequent Transactions?
- How Can I Use Temporary Disks of TaurusDB?
- What Is the CPU Usage of a TaurusDB Instance with Empty Load?
Database Usage
- Why Are the Results Inconsistent After the MATCH AGAINST Statement Is Executed, Respectively, on Primary Nods and Read Replicas?
- How Do I Add Columns Using INSTANT?
- How Do I Use LOAD DATA to Import Local Data?
- How Do I Write Data to or Create Indexes for an Ultra-large Table?
- What Are the Risks of Deleting an Index from an Ultra-large Table?
- Backups
Database Parameter Modification
- How Do I Change the Time Zone of a TaurusDB Instance?
- How Do I Configure a Password Expiration Policy for TaurusDB Instances?
- How Do I Ensure that the Database Character Set of a TaurusDB Instance Is Correct?
- How Do I Use the utf8mb4 Character Set to Store Emojis in a TaurusDB Instance?
- How Do I Set Case Sensitivity for TaurusDB Table Names?
- Can I Use SQL Commands to Modify Global Parameters of My TaurusDB Instance?
- Network Security
Log Management
- Can I Enable general_log for TaurusDB?
- How Do I View All SQL Statements Executed by TaurusDB?
- How Do I Enable and View Binlog of My TaurusDB Instance?
- How Do I Change the Binlog Retention Period?
- How Do I View Deadlock Logs of TaurusDB?
- Why Are Slow SQL Statements Displayed in Slow Query Log Monitoring, but No Information About Them Is Displayed on the Slow Query Logs Tab Page in the Logs Module?
- Version Upgrade
Troubleshooting
Backup and Restoration Issues
- Insufficient Permissions During Data Export Using mysqldump
- How Do I use mysqlbinlog to Obtain Binlog Files?
- Canal Fails to Parse Binlogs
- Precautions for Exporting Large Tables Through mysqldump
- Commands for Exporting Data Through mysqldump
- System Inaccessible After Field Addition to a Database Table
- SQL Statements Such as SET @@SESSION.SQL_LOG_BIN Displayed After You Run mysqldump
- Insufficient Privileges Reported for Canal
Connection Issues
- Login Failed After ssl_type of root Is Changed to ANY
- Failed to Connect to a DB Instance Using SSL
- Description of Each IP Address
- SSL Connection Failed Due to Inconsistent TLS Versions
- Error Message "connection established slowly"
- "Access denied" Displayed During Database Connection
- Failed to Connect to a Database Using mariadb-connector in SSL Mode
- Failed to Connect to a Database as User root
- Client Automatically Disconnected from a DB Instance
- Disconnection Occurs Every 45 Days Due to the istio-citadel Certificate Mechanism
SQL Issues
- Invalid TIMESTAMP Default Value during Table Creation
- Failed to Change the VARCHAR Length Due to the Index Length Limit
- Slow SQL Queries After a Large Amount of Data Is Deleted from a Large Table
- Error 1366 Reported When Data Containing Emojis Is Updated
- Slow Stored Procedure Execution Due to Inconsistent Collations
- ERROR [1412] Reported for a DB Instance
- Failed to Delete a Table with a Foreign Key
- Incorrect GROUP_CONCAT Results
- Error Message "Too many keys specified" Displayed When a Secondary Index Is Created
- DISTINCT and GROUP BY Optimization
- Equivalent Comparison Failures with Floating-Point Numbers
- A Large Number of SELECT Requests Routed to The Primary Instance After Database Proxy Is Enabled
- Tablespace Bloat
- ERROR 1396 Reported When a User Is Created
- Error Message Reported When alter table xxx discard/import tablespace Is Executed
- Native Error 1461 Reported by a DB Instance
- "Row size too large" Reported When a Table Failed to Be Created
- Duplicate Data Exists After ORDER BY LIMIT Is Executed
- Error Message Reported When select * from sys.innodb_lock_waits Is Executed
- Parameter-related Issues
Performance Issues
- High CPU Usage
- Out of Memory (OOM) Errors
- Tablespace Bloat
- Read Replica Uses Far More Storage Than the Primary Node
- Slow SQL Execution Due to Hot and Cold Data Problems
- Full Storage Caused by Complex Queries
- Slow Response Due to Deadlocks
- CPU Usage Increase
- CPU Resource Exhaustion Caused by Too Many Concurrent Slow Queries
Basic Issues
- How Do I View the Used Storage of My TaurusDB Instance?
- Renaming Databases and Tables
- Character Set and Collation Settings
- Auto-Increment Field Value Jump
- Starting Value and Increment of AUTO_INCREMENT
- Changing the AUTO_INCREMENT Value of a Table
- Failed to Insert Data Because Values for the Auto-increment Primary Key Field Reach the Upper Limit
- Auto-increment Field Values
- AUTO_INCREMENT Not Displayed in the Table Structure
- Impact of Creating an Empty Username
- No Scanned Rows Recorded in Slow Query Logs
- "handle_sync_msg_from_slave my_net_read error:-1" Displayed on the Error Logs Tab Page
- ERROR 1290 (HY000): The MySQL server is running with the --sql-replica-on option so it cannot execute this statement
- Videos
Show all
Viewing Suggestions on TaurusDB Parameter Tuning
Parameters are key configuration items in a database system. Improper parameter settings may adversely affect database performance. This section describes some important parameters for your reference. For details, see MySQL official website.
For details on how to modify TaurusDB parameters on the console, see Modifying Parameters of a DB Instance.
Performance Parameters
- innodb_flush_log_at_trx_commit
Function: Controls the balance between strict ACID compliance for commit operations and higher performance.
1: InnoDB writes data in the log buffer to log files and then flushes the data to distributed storage at each transaction commit. The ACID properties of transactions are ensured.
0: InnoDB writes data in the log buffer to log files and then flushes the data to distributed storage every second.
2: InnoDB writes data in the log buffer to the file system cache at each transaction commit, and flushes the data to distributed storage every second.
Impact: If this parameter is not set to 1, data security is not guaranteed. One second of transactions can be lost in a crash.
Recommended value for PoC: 0. This setting can significantly improve write performance in low concurrency scenarios.
- rds_global_sql_log_bin
Function: Controls whether to enable or disable binlog. TaurusDB uses a shared storage architecture. The primary node and read replicas in a DB instance do not depend on binlogs for data synchronization. You can disable binlog as required.
OFF: Binlog is disabled. The setting is applied to both existing and new connections without an instance reboot.
ON: Binlog is enabled. The setting is applied to both existing and new connections without an instance reboot.
Impact: Enabling or disabling it does not affect your instance.
Recommended value for PoC: OFF. This setting can improve write performance.
- In 2.0.42.230601 and earlier versions, binlog is enabled by default. To enable or disable it, you need to configure the log-bin parameter and then reboot your instance.
- In 2.0.45.230900 and later versions, binlog is disabled by default. To enable or disable it, you need to configure the rds_global_sql_log_bin parameter.
- rds_plan_cache
Function: Controls whether to cache the execution plan of a PREPARE statement.
ON: The execution plan of the PREPARE statement is cached. The cached execution plan can be reused in the next execution, improving query performance.
Impact: The query performance of the PREPARE statement is greatly improved, and the select_random_ranges test model of sysbench is significantly enhanced.
Recommended value for PoC: ON. This setting can improve query performance.
- This feature can be enabled in 2.0.51.240300 and later versions.
- rds_plan_cache uses the memory allocated by the stmt mem memory area instead of the innnodb_buffer memory.
- rds_plan_cache_allow_change_ratio: Table data change rate caused by query operations such as DML. If the change rate exceeds this parameter value, plan caches become invalid. If this parameter is set to 0, plan caches are not affected by the table data change ratio. They are always valid.
