Help Center/ TaurusDB/ User Guide/ HTAP Analysis (Standard Edition)/ Lifecycle Management/ Deleting a Pay-per-Use Standard HTAP Instance
Updated on 2026-09-16 GMT+08:00
You can delete any unused pay-per-use HTAP instances on the HTAP Analysis page.
To delete a yearly/monthly HTAP instance, you need to unsubscribe the order. For details, see Unsubscribing from a Yearly/Monthly Standard HTAP Instance.
Precautions
  • HTAP instances cannot be deleted when operations are being performed on them.
  • Deleted HTAP instances cannot be recovered. Exercise caution when performing this operation.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, locate a TaurusDB instance and click its name to access the Basic Information page.
  4. In the navigation pane, choose HTAP Analysis.
  5. Locate an HTAP instance and click Delete in the Operation column.
  6. In the displayed dialog box, enter DELETE as prompted and click OK.
    Figure 1 Deleting an HTAP instance
