Help Center/ TaurusDB/ User Guide/ HTAP Analysis (Standard Edition)/ Enabling Request Distribution Among Row Store and Column Store Nodes for Complex OLAP Queries
Updated on 2026-05-07 GMT+08:00
OLTP workloads involve both read and write requests in most cases. Write requests are processed by the primary node, and read requests are processed by read replicas or the primary node. OLAP workloads involve only read requests in most cases. Read requests are processed by HTAP nodes.
If your system handles both OLTP and OLAP workloads, you can use column-store indexes to distribute OLAP requests to HTAP nodes and OLTP requests to read replicas through a proxy address for optimal efficiency.
  • Read replicas: process read requests based on row store. Row store nodes deliver higher performance when processing OLTP read requests.
  • HTAP nodes: process read requests based on column store. HTAP nodes outperform read replicas when processing OLAP read requests (such as complex SQL and analytic SQL queries).
Request Distribution Methods
Automatic request distribution and manual request distribution are supported.
Table 1 Request distribution methods
Method
Constraint
After this function is enabled, a proxy instance distributes requests based on the actual execution cost of a SQL statement to maximize the query performance.
Criteria:
  • Requests that fall below or reach the execution cost threshold of a SQL statement are distributed to read replicas (or the primary node). If there are multiple read replicas, the system distributes requests among them based on their assigned weights.
  • Requests that exceed the execution cost threshold of a SQL statement are distributed to HTAP nodes. If there are multiple HTAP nodes, the system distributes requests among them based on their assigned weights.
  • Currently, only standard HTAP instances support request distribution among row store and column store nodes.
  • Automatic request distribution among row store and column store nodes only supports the weighted routing policy.
  • Automatic request distribution among row store and column store nodes only supports the read/write proxy mode. The read-only proxy mode is not supported.
  • Automatic request distribution among row store and column store nodes only supports eventual consistency. Global consistency and session consistency are not supported.
  • Automatic request distribution among row store and column store nodes does not support session-level connection pooling.
  • SELECT FOR UPDATE is not supported.
  • Custom variables are not supported.
  • Prepared statements are not supported.
Manual request distribution
If automatic distribution does not work as expected, you can use the HINT syntax to forcibly execute a row store or column store execution plan.
Databases whose names contain Chinese characters cannot be synchronized. The destination database and task names cannot contain Chinese characters, and the destination database name must contain at least three characters.
  • Parameters have been configured for a TaurusDB instance according to the following table.
    Table 2 Parameter description
    Value
    How to Modify
    binlog_expire_logs_seconds
    86400
    Modifying Parameters of a DB Instance
    It is recommended that the binlog retention period be greater than one day. 86,400s = 60 (seconds) x 60 (minutes) x 24 (hours). This prevents incremental replication failures caused by a short binlog retention period.
    rds_global_sql_log_bin
    ON
    How Do I Enable and View Binlog of My TaurusDB Instance?
    To use this parameter, ensure that the kernel version of your TaurusDB instance is 2.0.45.230900 or later.
    For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
  • Databases and tables have been created for the TaurusDB instance.
