Help Center/ TaurusDB/ User Guide/ DBA Assistant/ Performance Monitoring/ Viewing Real-Time Performance Metrics
Updated on 2026-07-16 GMT+08:00
TaurusDB allows you to view performance metrics and trends of DB instances in real time, helping you detect and handle potential performance problems in a timely manner.
Viewing Real-Time Metrics
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name.
- In the navigation pane, choose Performance under DBA Assistant to check the performance metrics of your instance.
Click Select Metric to add or delete performance metrics.
Figure 1 Viewing real-time performance
Configuring Monitoring by Seconds
- Click
- In the navigation pane, choose Performance under DBA Assistant.
- Click Enable Monitoring by Seconds.
- In the displayed dialog box, enable Monitoring by Seconds and click OK.
- This function is unavailable for any DB instances with fewer than eight vCPUs.
- Once you turn on this function, the system will report monitoring data again and show it in about 5 minutes.
- You can turn off this function if needed. Once it is turned off, the system will report monitoring data again and show it in about 5 minutes.
Figure 2 Enabling monitoring by seconds
