Changing Permissions for Accounts
You can authorize custom database users to specified databases and revoke permissions for authorized databases.
- This operation is not allowed when another operation is being performed on your DB instance.
- Take care when changing account permissions. Inappropriately configured account permissions can impact the DB instance or workloads.
- If you grant permissions on both all and specific databases to an account, the account's actual permissions are a combination of them.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name.
- In the navigation pane, choose Accounts. On the displayed page, locate the target account and choose More > Change Permission in the Operation column.
- In the displayed dialog box, change account permissions.
Select one or more unauthorized databases and authorize their permissions to the account. To delete a selected database, locate the database and click × in the Operation column.
Table 1 lists the read-only and read/write SQL permissions.Table 1 Permissions Permission Type
Permission
Read only
GRANT SELECT, LOCK TABLES, and SHOW VIEW
Read and write
GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, REFERENCES, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES, EXECUTE, CREATE VIEW, SHOW VIEW, CREATE ROUTINE, ALTER ROUTINE, EVENT, and TRIGGER
Figure 1 Changing permissions
- On the Accounts page, check that the authorized databases and permissions of the account have been changed.
