Help Center/ TaurusDB/ User Guide/ Instance Management/ Instance Lifecycle Management/ Modifying a DB Instance Description
Updated on 2025-12-31 GMT+08:00
After a TaurusDB instance is created, you can add a description to it.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, locate an instance and click
in the Description column to edit the instance description. - The instance description can contain a maximum of 64 characters, and cannot start with or end with a space. Only letters, digits, hyphens (-), underscores (_), periods (.), and spaces are allowed.
- To submit the modification, click OK. To cancel the modification, click Cancel.
Alternatively, click the instance name to go to the Basic Information page. Locate Description in the Instance Information area, and click
to edit the instance description.- To submit the modification, click
. - To cancel the modification, click
- View the results on the Basic Information page.
