Updated on 2026-02-02 GMT+08:00
Deleting a Database
You can delete databases you have created.
- Deleted databases cannot be recovered. Exercise caution when deleting a database.
- This operation is not allowed when another operation is being performed on your DB instance.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name.
- In the navigation pane, choose Databases.
- On the displayed page, locate a database and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE as prompted and click OK. Figure 1 Deleting a database
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
- Check that the database is no longer displayed on the Databases page.
