Updated on 2026-07-16 GMT+08:00
Configuring Auto Throttling
In high-concurrency internet applications, sudden traffic spikes or abnormal reads/writes can slow system response, affecting user experience and service continuity. Auto throttling allows you to set criteria, such as the vCPU threshold, maximum number of active connections, duration, and maximum concurrent requests. To maintain availability of mission-critical workloads, the system throttles the requests on sessions that meet the criteria.
Currently, auto throttling can only be configured for the primary node. You can view valid throttling rules on the SQL Throttling tab.
Supported Versions
The kernel version of your TaurusDB instance must be 2.0.69.250900 or later.
For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
  • Auto throttling can only be configured for the primary node. It is not available for read replicas.
  • Enabling auto throttling automatically enables SQL throttling.
  • No more than 10 SQL throttling rules can be automatically generated. A maximum of 100 SQL throttling rules are allowed.
  • Throttling rules generated after Auto Throttling is triggered will be automatically deleted upon expiry. You can also manually delete them on the SQL Throttling tab. If Auto Throttling is modified or disabled, the generated throttling rules will be automatically deleted.
  • SQL throttling rules that are automatically generated after auto throttling is enabled are applied to new SQL statements, not to those already running.
  • If there is a throttling rule with the same keywords as you specified, no new rule will be automatically generated.
  • Throttling rules are generated only for SELECT.
  • Auto throttling generates throttling rules based on sessions of non-root accounts.
  • Restoring your instance data from a backup will clear SQL throttling rules and auto throttling settings.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, click the target instance name.
  4. In the navigation pane, choose SQL Analysis and Tuning under DBA Assistant.
  5. Click the Auto Throttling tab.
  6. Click Auto Throttling. In the displayed dialog box, turn on the Auto Throttling switch and configure required parameters. This will automatically throttle SQL execution under high load, protecting the system from being overloaded. For details about the parameters, see Table 1.
    Example:
    In the time window 15:00–20:00, if the CPU usage is greater than or equal to 90% and the number of active sessions is greater than or equal to 20 for 5 minutes, auto throttling will be triggered.
    The maximum duration of each throttling is 5 minutes. If any of the CPU usage, number of active sessions, and duration no longer meets the throttling policy, the throttling will be stopped.
    Figure 1 Example configuration
    Table 1 Parameter description
    Time Window
    Select a proper time window.
    Max. Duration (min)
    Maximum length of time that SQL statements matching the auto throttling policy can be throttled on the primary node within the time window.
    If the maximum duration is exceeded, the throttling stops automatically. If the criteria remain unchanged, the next throttling will be triggered 1 minute later.
    Range: 1–1440
    vCPU usage (%)
    This threshold helps assess instance load. If the vCPU usage exceeds the threshold (≥ 70%), the system determines whether to trigger auto throttling based on the relationship between vCPU usage and active sessions (and/or).
    Active sessions
    This threshold helps assess the number of concurrent accesses to an instance. If the number of active sessions exceeds the threshold, the system determines whether to trigger auto throttling based on vCPU usage.
    Range: 1–5000
    Duration (min)
    Auto throttling is only triggered when vCPU usage and active session thresholds are sustained throughout the observation period you specify.
    Range: 2–60
    Max. Concurrent Requests
    This parameter limits how many SQL statements matching the keyword can be executed concurrently. Any statements beyond this limit will not be executed.
    Range: 1–1000000000
    SQL Throttling Rule
    If Retain is selected, existing SQL throttling rules will be retained.
  7. Click OK.
  8. After auto throttling is triggered, SQL throttling rules will be automatically generated. Check valid throttling rules on the SQL Throttling tab.
