Updated on 2025-10-11 GMT+08:00
Viewing and Removing Mappings
You can view the mapping list on the Memory Acceleration Management page and remove mappings.
Usage Notes
- After a mapping is removed, service applications cannot obtain the latest data of the source database from the acceleration instance.
- The corresponding mapping rule will be cleared after a mapping is removed.
- If the source instance or acceleration instance is not normal, the mapping cannot be removed.
Querying the Mapping List
- Log in to the GeminiDB console.
- In the navigation pane on the left, choose Memory Acceleration Management. On the displayed page, search for your target mapping by keyword (such as the mapping name or mapping ID).
Figure 1 Mapping list
Removing a Mapping
- In the navigation pane, choose Memory Acceleration Management. On the displayed page, locate the target mapping and click Remove in the Operation column.
Figure 2 Memory acceleration management
Figure 3 Removing a mapping
