Help Center/TaurusDB/User Guide/TaurusDB Memory Acceleration/Modifying and Deleting a Memory Acceleration Rule
Updated on 2025-10-11 GMT+08:00
A memory acceleration rule can automate data synchronization from TaurusDB to GeminiDB. You can also modify and delete this rule.
Usage Notes
- Currently, only hash data from TaurusDB can be converted to GeminiDB Redis API.
- If a table name of the TaurusDB instance in the memory acceleration rule is changed, you need to reconfigure the rule.
- Currently, the ENUM, SET, and JSON data cannot be synchronized.
- If you rename or delete one or more key fields of a memory acceleration rule, the rule becomes invalid.
Modifying a Mapping Rule
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the navigation pane on the left, choose Memory Acceleration. In the Mapping Rule area, locate the target rule and click Edit in the Operation column.Figure 1 The Edit button
- After editing the fields, click Submit.Figure 2 Editing a mapping rule
Deleting a Mapping Rule
- Click
in the upper left corner and select a region and project. - On the Instances page, click the target instance.
- In the navigation pane on the left, choose Memory Acceleration. In the Mapping Rule area, locate the target rule and click Delete in the Operation column.
