Help Center/
TaurusDB/
User Guide/
TaurusDB Memory Acceleration/
Enabling and Using Memory Acceleration
Updated on 2025-09-04 GMT+08:00
This section describes how to enable memory acceleration. The process is as follows:
Using the Memory Acceleration Module
Usage Notes
- This function is now in OBT. To use it, choose Service Tickets > Create Service Ticket in the upper right corner of the console and contact the customer service.
- After memory acceleration is enabled, commands such as RESET MASTER and FLUSH LOGS used to delete binlogs on TaurusDB instances are not allowed.
- A Redis key prefix and a delimiter in a new rule can neither include those nor be included in those specified for an existing rule. For example, if the key prefix in a new rule is pre1: and is separated by a comma (,) and the key prefix in an existing rule is pre1 and is separated by a colon (:), the new rule cannot be created.
- Currently, the ENUM, SET, and JSON data cannot be synchronized.
- Currently, only single-table queries are supported during lightweight incremental synchronization. Joint queries are not supported.
- Only GeminiDB Redis instances are charged. There are no other fees for this function.
- When you purchase a TaurusDB instance, if you select Buy Now for memory acceleration, a GeminiDB instance is automatically provisioned with DB Cache enabled. You can skip instance creation and start from Creating a Mapping Rule.
